W124 ecu
Markmad50
W210 320cdi estate
Does anyone know if or how a immobiliser is in the engine ecu .
N reg 2.8
Ecu 016545783207
It had a infra red key . I have put the engine box . Engine loom and ecu in to a earlier w124, the same two plugs in the fuse box and two plugs from gearbox. It has no different wires on the engine loom going to car loom . So i cant see how it haves a immobilized ecu . I have no spark from coils everything else lives up and turns over .
balge59
Nottingham
1993 190E 2.0 Automatic
if it's an option there should be a code for it? on the plaque thing?
DREAMER NO2
W124 2.6E M103 1989
Alarms are never incoperated in the ECU it will be a stand alone unit.
And each part in the electrical system must have the same part number on them, you cant just plug them in because the look the same . So you cant change early parts on to an new model .
M
Markmad50
W210 320cdi estate
All running now . And yes you can put newer parts on a older car . I have a 1990 230coupe and i have fitted s 1995 2.8 engine. Engine loom and ecu and it plugs into the car loom . My trouble was my crank sensor wire to ecu with shorting with its self
balge59
Nottingham
bosch stuff used to be quite good at backwards compatibility
