W124 Engine power surges then stalling
Wizz Jones
Hi Folks
I have an intermittent problem with my 1990 W124 260E.
Sometimes the engine will surge erratically and then stall.
Anmy ideas please?
emimec
London
1989 124 series 260e, 1992 124 series 260e (written off, used as spares), 1991 260e 124 series
wish I could answer this one, because my 260e is doing very similar things, lumpy idle sometimes, no tickover at all sometimes, and stalled on me 3 times today at traffic lights. The only thing I havnt done yet is change the fuel filter, which may well be our answer !!!
Bob
rayhennig
1991 300CE-24 Sportline
Hi Folks
Anmy ideas please?
The first thing is to eliminate ALL inlet vacuum leaks.
After that, make sure that plugs, cap, rotor and leads are in fine condition.
Make sure air and fuel filters are good.
Then check injection duty cycle.
Don't assume that anything expensive is broken until proven otherwise. 90% of the time it's neglect rather than failure.
RayH
Geewizzpip
300CE. 1990. 3.0
If it’s high mileage, try disconnecting the engine breather pipe to the air filter. Bad or oily air really messes with the fuel injection system. It’s the simplest thing at cures most running issues. I found this out after two completely new dizzies and HT leads making no difference.
Hello and welcome,
10 year old thread you’re replying to…
mattkh
England
A160 W168 1999 1.6
The oily air will pass thru the air filter which will trap the oil. ????
Not_Anumber
S212 E350cdi prefaclift
Best to use an oil catch tank for the breather ?
www.ckinsurance.co.uk
