W124 fault codes
5907
I checked the codes on my '95 E280 to see if there were any clues to the intermittent hunting idle and lack of top-end power, and got the following on pin 8:
13 O2S (Lambda) control system operating at rich or lean limit
35 Model 124,129 and 140 AIR pump switchover valve and/or electromagnetic AIR pump
clutch. Model 202 AIR pump switchover valve and/or AIR relay module
I can see what 13 means, but 35 doesn't mean anything to me.
I was hoping for code 4 to finally prove that the MAF is faulty, but code 4 didn't show up. Does this mean I need a new Lambda sensor?
Your codes all point in the same direction ---running too weak
It would appear that the lambda is at fault, the air pump when fitted further weaken the fuel mix when it gets too rich,
The MAF can cause the above symptoms by giving false info and making the mixture too weak
5907
Do you think maybe the Air pump isn't switching off properly, and making the mixture too lean?
kth286
E320 Coupe 95
They may of course be codes that have not been cleared from previous work.
I would always clear the codes and go for a drive and check again.
Very few cars have them in this country,do you have one
5907
Not 100% sure; I think my last 300TE had one though, isn't it the Air pump that makes a racket for about 2 minutes after a cold start?
