W124 - Instrument lights not working
and have you tried squinting at them while repeatedly turning the dimmer knob to see if they even flicker? at night?
I will take a look this evening, and see what other way one can test
H
howzat1976
Ealing
Old Skool
  • #23
yes, i have no lights. Its strange it use to work fine. No problems before
The ashtray illumination comes from pin 13 Grey/ white
I was right when I said that there is a lamp module for cars that have electric windows and heated seats.
I have sent you the paper
another fault has just come to me. the dimmer control uses a ballast resistor, and consequently gets very hot when the lights are dimmed. i have known the soldered contacts on the brass strip on the back come unsolder-ed.
Not with the module fitted,,that is the purpose of it, to take away the high current..
I can send you the details to save looking it up
there you go, 230K, that's exactly what i mean't - easy fix too.
H
howzat1976
Ealing
Old Skool
  • #29
Thanks, very useful. The guy at MB Brentford said the same thing he said the whole unit sells for £19.50. I'll Try and have a look, Im off to Dubai on Sat. Thanks guys for all your help, I'll keep you updated.
Regards
Vass
H
howzat1976
Ealing
Old Skool
  • #30
Hi, Its been a while, finally got it fixed, at the back of the dimmer the connection came loose. Just needed a quick solder. Thanks to all that helped
Regards
Vass
H
howzat1976
Ealing
Old Skool
  • #31
Thanks, you were right the connection came loose. Quick solder all good now
Thanks agian
Vass
cue smug grins all round. :D
roadhog
Sunny Norfolk
W124 300D x2, C124 300
Thanks for the update as well, so many threads are left open ended. :)
