They were a cost option on pretty much all 124's at the time of ordering.
Should be pretty much a straight swap,although I think that the d/shafts were different.
I don't really do electrics (witchcraft) but presumably the LSD itself is just a plate or torque biasing type (entirely mechanical) and could be used without the traction control system simply to redirect torque when one wheel loses traction?
Alas, no.
ASD is a hydraulic locking diff - if you go up a level or two on the Russian site, and look under hydraulics, you'll find the piping run and the extra accumulator which is fitted to the underbody.
The system takes input from the ABS sensors, and when slip is detected applies hydraulic pressure to the diff, locking the output shafts together. It's a complex system, and it's very much designed for allowing you to set off and drive slowly on slippery surfaces rather than a high performance, high speed device.
WE HAVE NOW MOVED: 8 Hazel Road, Woolston, SO19 7GB Service, Repairs and remapping service Any queries, please do not hesitate to contactEmail@mbsofsouthampton.co.ukor alternatively you can phone Colin or Dave on 02380 445820, out of hours numbers are 07787913313 or 07907631681.
