W124 sunroof maintenance
swannymere
Hampshire
S124 1994 E300D
Anyway, finally got around to taking a look at the sunroof. It tilt's but wont slide, so i put it up and then sprayed Teflon spray anywhere mechanical looking, no joy! Had a go with winding it from the boot and it lowers on the drivers side but won't on the passenger side? Tried applying some pressure to the side that wasn't lowering but had no joy :neutral: Any more ideas?
Would you like some service instructions
mikestrivens
Stockport
I would love some for my sunroof if it is not too much trouble, not that I've had much chance to use it this year.
fullmeister
Northumberland
w124 250D estate
The sunroof relay is located on the motor . A plastic clip holds in in place :eek:)
A few paper sent for you to you Mike to sort through:D:D
mikestrivens
Stockport
Many thanks Malcolm, I appreciate your help. I assume the mechanism is pretty similar, if not identical, in W124 and W140 models.
Why not put your E mail address in your profile,,and save changes at the bottom of the page
swannymere
Hampshire
S124 1994 E300D
Put my E mail address in my profile, not sure what the save changes part of your answer refers too? Apologies if i'm being a bit thick :confused:
The Crooner
The Crooner
Woodhall Spa Lincolnshire
2006 R320 cdi
  • #30
Sorry to resurrect an old thread
On page 1 Wireman refers to the adjusting screw adjacent to the winding point.
Can anyone please confirm that the purpose of this screw is not to move the cable, but to adjust something behind the cable path?
My problem would seem to be that the plunger part of the adjuster has two slots which look like they should align into the female part at the back.
There is nothing to align these to, and I think therefore that the adjustment achieves precisely nothing.
Should I try and insert i screwdriver and give it a tweak?
Or does anyone have a better idea.
My symptoms are as descibed earlier in the thread.
Tony
I do have info on the cables but I did not include that in what I sent
I will have to go and print them off,it will not take too long
I have sent you a whole pipe as i cannot remember what I have sent before
The Crooner
The Crooner
2006 R320 cdi
  • #35
I received the pipe, thank you.
Reading for tomorrow over breakfast.
Thanks as usual
Tony
Thanks as usual
Tony
Always a pleasure,, just ask if you need anything else :D
