w124 woes.
coupeblack114
Hi, my 300td has developed a fault on the main beam dipp switch by where it is stuck on main beam. Is there a relay somewhere on the vehicle for the switch or do i have to remove the wheel and inspect the switch
Best wishes, nic
grober
Scotland
W204 C200cdi estate
I would check the relevant fuses first 13,14,15,16 in the fuse box beside the brake servo unit. They can develop a layer of corrosion where they clip into the fuse holders. Failing that check the exterior lamp failure Monitor unit in the relay compartment behind the fuse box. You will have to undo several screws in the fuse box frame to get access. Unfortunately the most likely candidate is the combination switch on the steering column which I think requires steering wheel removal to renew.
C
coupeblack114
Thanks, will investigate. i have renewed the light control unit so i think i will start with the fuses and then the switch.
Regards, Nic
Alex Crow
Super Suffolk
i would guess with boldie on this one.
