W126 Parts wanted 1987 300se
ben300se
Bedford
www.justgiving.com
Looking for;
  • electric window motor for drivers side.
  • Drivers Door card pieces - the metal bit around the door release.
  • Spare wheel.
Advise needed.
  • Just given it a full service and now starting to get a juddery feeling when cruising on motorway, as if it doesn't want to maintain speed?
  • On occasion the revs do there own thing and can cut out?
B
ben300se
Bedford
www.justgiving.com
  • #2
Work carried out so far!
The main thing I'm experiencing now is a motion (at 60 - 70 on the motorway) that feels like someone is gently rocking the seat back and forth;
As if it can't keep a constant speed?
Also;
  • could it be the new liquids/parts are settling?
  • At idol the revs sometimes increase then it dies?
  • The gear shift is jumpy heavy when accelerting at speed, around town its smooth?
  • I'm no mechanic but possibly it's not breathing properly?
Managed 175miles of half a tank since service!!!
Work carried out to date:
At garage after collection.
  • Refitted exhaust.
  • New plugs (found 4 & 6 knackerd and not firing).
My dad and me:
  • Oil Flush
  • New Oil
  • New Oil filter
  • New Sump plug/washer
  • Engine stop smoke
  • Engine stop leak
  • Rad Flush
  • Fresh water and Anti-freeze
  • New Air filter
  • Carb cleaner
  • Oil stop leak to box (for Auto box)
  • New wipers
  • Bulbs
  • Checked pads - OK!
  • New tyre
To do:
  • Tried fixing ventilation. Blower not working, Drivers elec window motor blow. Decided to replace that only. Need to find one or poss remove?
  • Raise money.
  • Get sponsored.
B
ben300se
Bedford
www.justgiving.com
www.justgiving.com/dingle-berry
It has been suggested: 'I'd say it's fuel.Try a new petrol filter and running a lot of redex through the tank'.
That had crossed my mind as somthing to change when we where tinkering before but I could not find it. All I could see was two large rubber pipes feeding the carb, Where is the filter?
What about HT leads od rotor arm, could these cause the problem?
Also; When under the bonnet I found an unidentifired device. It is positioned in the tray behind th bulkhead, near the wipers. It is small, black, has a wheel button that can be rotated and has letters printerd in it. Any idea???
