W140 s class 2.8 ASD warning light
380560
Isle of Skye Highlands
S Class, W140 4.2 Limo, Nissan 300ZX twin turbo, Porsche 911.
Hi The ASD warning light has just come on on my W140 2.8 and also the warning triangle, but goes out when the brake pedal is pressed. I have checked the brake fluid level and it is at the correct level. Can anyone please help?
The OVP relay is one possibility
380560
Not Sure what that relay is or where it is? Could you please advise how I find it and how I test it. Thanks
They are normally up against the bulk head under a cover, they are pigs to test as you cannot get to the terminals, there are 3 pin 87 outputs a,b and c
What year is the car please
380560
It's 94 L reg with 69,000 miles
You could have a fault code read out, does the lamp come n as soon as the engine is started
380560
Yes both the triangle warning light in the dial and dash light stay on when the engine is started but goes out when the brake pedal is pressed and on again when released. It only started tonight, at first i think the triangle light was slow to go out, then I noticed both remained on.
It will nave to have a code read out, a blink code reader will do it, I sell them £15
380560
I didn't know one could do this on this age of vehicle, where do you plug it in. I will probably buy one off you, how do I pay you for it.......oh and those lock covers look a good thing especially up here on Isle of Skye!!!
380560
Thanks for that, does it show me where I plug this bit of kit in assuming that is what you do!!!?
Yes if you open that link I put up it tells you all about the pin out sockets
380560
Thanks, I think I must be an air head as I can not see where the plug is on the link you sent. There is a page where there is no image available is that the page? if not could you please give me the page number.
I would like to buy one of your readers and 3 door lock covers, please advise how I can pay via you paypal account.
It is or should all be on the inside of the offside front wing, under the plastic cover with the winged head screws. .
I will find you exact details as I need to know what socket is in the car, its too early I think for the 38 pin.
Email sent with details
380560
Thanks I will check. I have sent the necessary as discussed!
OK thank you please undo that cover and see what socket is there. If the 38 pin it needs different leads and I must know that and I will provide the 38 pin pin outs
380560
  • #19
I have removed a plastic cover near the coolant expansion tank is located I can only find right next to this tank is a round cabletied and lead sealed plastic cover which is approx a 2 pence diametre and is numbered 1 to 7 in a clockwise direction. it looks as if it has not been touched or opened since manufacture! I have looked all around the wing area and can not find anything resembling what you have described. Could you send a diagram please?
See what I can find this evening
