You will wish you hadn't. Unless you get very stiff springs, you will lose nearly all the bump absorbing movement in the struts and be spending a lot of time on your bump rubbers. Extra stiff springs will shake the fillings out of your teeth:lol:
The only real option, if you are determined to do it, is to remove the rear struts and have the spring seats cut from the strut and re-welded in a lower position - I still think 2" is too much. This then allows the car to ride normally in a lower on road position. Front is easily dropped but, once again, you will have little suspension movement before bottoming and no way to stop that on the front.
