W169 motor change- problems with misfire
A150-2008
Hi there
A150 with 1,5 94 /2007 - engine seized and I bought a new (old) m266.920
Engine is installed and fires right up and smooth idling! However when applying some load/ rpm cylinder 2 and 3 «flutters» and quits...
Diagnostic says misfire on 2 and 3 changed coils, new spark plugs, plug wires..
the new eninge is equipped with the ecu that was originally with the old motor - however the «cable harness» is the original that came with the new engine...
we have tried to clear fault codes, but still same symptoms- any ideas?? warmly welcome
mioba
Nottingham and Köln
check your fuel lines to said cylinders
