W169 panoramic sunroof help
Carl Tweedie
Registered
Mercedes A180cdi 2009
Television passed away 3 years ago.
@GLK may be able to help.
ZZZZ
No first hand experience, as my roof is solid metal (a rusty one, I'm sure - it is a Mercedes), but hopefully these files should help:
https://we.tl/t-2PEJ1leByJ
38 files, so had to zip and upload to WeTransfer.
The link is only there for 7 days.
benz michael
A180 CDI
Sun roof problem.
hi, my first post, the model is Webasto a 169 780 01 44, its the 5 panel model , it will open and close the rear 4 with no problem, when it gets to the wind deflector panel it stops, if you knock the two metal arms or pegs it drops down.
at this point it is closed but if you drive off it starts to whistle. I am in Italy and its 34 deg so no chance of rain.
if i then try to open it it lifts the wind deflector with no problem and then the other 4 panels slide back.
basically it only doesn't close the wind deflector and dosent seal properly when you over ride it.
Just went to an Italian mercedes dealer, 400 euros just to look at it.
If i could work out what is broken i would order and fix it my self.
thanks every one.
ZZZZ
Welcome Michael,
Have a look at the files I posted above - all about fixing and replacing lamella / panoramic roof.
benz michael
A180 CDI
Hi GLK
I down loaded them and read the relevent ones, its not clear to me if it is the cable or a piece broken off a guide, but thanks anyway
ZZZZ
No worries.
Obviously those workshop information files won't be able to diagnose the problem, but should be helpful fixing it ;)
benz michael
A180 CDI
i found the break, can any one recommend replacements parts for the front corner unit for lifting the wind deflector.
ZZZZ
Simple plastic parts, assuming that's what it is, are often cheaper direct from Mercedes - I've seen used and battered ones on eBay at double the price of a brand new part from my local MB ...
MarkW169
W169 a150 2006
Hi GLK, would you be so kind to put a new link to the files? Hope it will help me to fix my roof. Thanks in advance
ZZZZ
I'll try to upload these here, bit by bit - would be better for everyone, I think.
10 files at a time, if I'm not mistaken ...
  • 245 adhesive impact absorber to headliner.pdf
  • 245 Adjust lamella roof.pdf
  • 245 Adjust lamellas on lamella roof.pdf
  • 245 Adjust panoramic roof.pdf
  • 245 Completely remove_install lamella roof.pdf
  • 245 Cut out headliner with cutting wire.pdf
  • 245 Electrical function schematic for lamella roof.pdf
  • 245 General notes_ Passenger cars_ Sliding roof, soft top, top attachments.pdf
  • 245 Install and weld in center roof paneling.pdf
  • 245 Prepare center roof paneling.pdf
ZZZZ
second batch
  • 245 Prepare headliner for installation.pdf
  • 245 Remove_install cable.pdf
  • 245 Remove_install center lamella from lamella roof.pdf
  • 245 Remove_install grab handle on roof.pdf
  • 245 Remove_install headliner.pdf
  • 245 Remove_install lamella guides on lamella roof.pdf
  • 245 Remove_install lamella roof drive.pdf
  • 245 Remove_install overhead control panel control unit.pdf
  • 245 Remove_install paneling on A-pillar.pdf
  • 245 Remove_install paneling on B-pillar.pdf
ZZZZ
third one:
  • 245 Remove_install panoramic roof.pdf
  • 245 Remove_install Parktronic System (PTS) warning display in rear passenger compartment.pdf
  • 245 Remove_install rear lamella on lamella roof.pdf
  • 245 Remove_install rear roller sun blind for lamella roof.pdf
  • 245 Remove_install roller sun blind for louvered sunroof.pdf
  • 245 Remove_install seal for lamella roof.pdf
  • 245 Remove_install sidebag unit in the rear.pdf
  • 245 Remove_install speaker in the A-pillar paneling.pdf
  • 245 Remove_install speaker in the C-pillar paneling.pdf
  • 245 Remove_install sun visor.pdf
ZZZZ
and the last one:
These are for W245, but almost everything is identical for W169.
  • 245 Remove_install trim at C-pillar.pdf
  • 245 Remove_install wind deflector lamella from lamella roof.pdf
  • 245 Replace complete center roof paneling.pdf
  • 245 Safety hook for tensioning roller sun blind for lamella roof.pdf
  • 245 Separate center roof paneling.pdf
  • 245 Tension roller sun blind.pdf
  • 245 Wiring diagram for electronic ignition switch (EIS) control unit.pdf
  • 245 Wiring diagram for overhead control panel (OCP) control unit.pdf
ZZZZ
No worries ;)
As I said, haven't dealt with this particular problem myself, however I have done a few mods on my C169 - will be happy to share.
David :)
Anthony scopelitis
New Registration
B200 2010 2.0
Hi there im new to the forum. I have a w245 b-200 2010 and i have the same issue. The lamella roof works fine but the wind deflector dosnt open or close. I know what the problem is. Its the rail guide plastic clips on both sides. I know were to order them from. The only problem is i have no idea how the fit the new guides in. Any help will be much appreciated thanks!
Fixerupagain
A160 2010
Hi, another newbie. Parents A160 Lamella wind deflector packed it in today with what sounded like snapping plastic. All the slats move as they should with just the front wind slat being affected. I've had a quick sniff and it looks like the infamous plastic parts are the culprit, as this thread would suggest. Has anyone done this repair without taking the sunroof/headlining out? Also, does anybody have the part numbers for the repair kit mentioned in this thread?
Any help apreciated.
Gracias
