W202 auto box probs
Algygale
Hi..
Ive been having trouble with me W202 c200k gearbox.
The throttle stops working when it seems i coast it into,say a roundabout..
It was doing it once a month & now its doing it more regular eg.90miles 60miles and did it twice today within 5 mins.
I have to switch off ignition & then its fine & so i have it down to a fine art to which i can do it whilst driving.
I dont get any warning lights come up or go into limp mode..surely it should?
Any ideas..would a stars tester show the prob?
Thanks...
Alan.
Sorry Alan,I dont quite understand whats happening,you dont have your foot on the throtle when you are coasting.
Malcolm
Ultymate
N. Wales
C230K Estate 1998
Alan do you mean the engine stalls or does it just idle and won't rev up:confused:
A
Algygale
Sorry..if i take my foot off the throttle & coast it up to a roundabout..when i put my foot back on the throttle doesn't respond.
It just sits at 1500 rpm. i can feel the box changing down when its coasting but doesn't stall.
When i flick the key off then back on its all ok for a while just seem to be doing it more regular.
Any ideas?
let me have the VIN next 3 numbers WDB202--- and see what I can find.
Malcolm
recieved thank you.
Malcolm
Yes this is a listed fault with 8 parts to change, nothing big just small components
I would get an Indie to do it,its all on Data sheet AF30.10-P-6100G
Malcolm
A
Algygale
Malcolm
Ok thanks television.. are they expensive parts & where do i find this data sheet?
Alan.
Alan.
They are all small modification parts including a pipe on your air intake to stop the vacuam in the over run.
You can ask MB to print this out for you, if they wll not,I can do it for you when I get same ink
Malcolm
Malcolm pls save yourself some money in the long run by getting a decent laser printer. :) If you want some recommendations I'm sure you will get plenty. Just check out the prices of consumables (toner) before buying. Should be a lot cheaper per page than inkjet.
Thank you Blobcat,if I can get every thing on one computer,with two HDs, then I do not have to print and then scan in order to send these things, thats my long term aim. I only just got on air today by system restore.
My other MB program is running on a machine with a 3.3 processor and 1024 of ram with high spec DVDs and DVi graphics, I think that I should upgrade that one, its almost new,only cost me a £1
Malcolm
A
Algygale
Malcolm
Ok thanks alot..i will try Mercedes first..but how did you get this info?
Alan.
Alan.
I cant put this info up here,you can always say that another MB dealer gave it to you, PM me if you wish.
Malcolm
