W202 C180 O2 sensor......
ernspurs
.... is it an easy job to fit a new one, and is it easy to get at.
Mind me asking why you think it has gone
E
ernspurs
Sorry for the delay in replying, my pc decided it did not want to play anymore!!
The management light is on, i have replaced the maf and the light is still on. The car runs rough on first start up, which clears after about 30 seconds and is then fine for the rest of the day. Also on the first start ther is a small amount of smoke from the exhaust which is again fine after about 30 seconds. I think that the o2 sensor is the next step. The car is a 2001 W202 c180 with the 1998cc engine.
E
ernspurs
Thanks for that Malcolm, am I correct in thinking that the one in front of the cat is more likely to fail out of the 2 and is it a diy job, eg can i do it if the car is up on ramps.
I will print off the instructions for the upper one later this evening,, please remind me so that I find the post again
E
ernspurs
Cheers Malcolm, you are a star.
i really think that guessing at the O2 sensor is wasting money - at least have the codes read! the O2 sensor is not used during or immediately after cold start, so is not going to make a difference to this particular problem, sorry.
matthewm1965
Durham
1999 W220 S500L, Toyota Supra Mkiv, 1970 Triumph GT6
As above, the o2 sensor doesn't come into play until the engine has warmed up.
I will wait for now
E
ernspurs
Thanks for that, I will take your advice and have the codes read.
ncstater
New Registration
Help getting to Bank 1 Sensor 1
Hi Television. I have a C280 W202 with a bad bank 1 sensor 1 oxygen sensor. I have tried to get to it from above and below, but no luck. Above, looks like I need to remove a bolt on the valve cover - hard to believe this is the proper method. From below, I have removed the 3 rubber hangers and the two bolt assembly holding the exhaust to the transmission. With all this unhooked, I have heard you will have access to the sensor, but again, no luck. Any advice?
