W202 Complex Problems
Looking at that connector you look to have the disintegrating wiring loom problem common on 1993-95 cars.
Mercedes changed the wiring harness insulation to a biodegradable plastic but unfortunately used a plastic that biodegrades whilst still in use, some cars having issues within a few years.
Top engine looms are very prone to it due to heat. My r129 had the issue and I had the engine and throttle body loom replaced to fix it.
The symptoms are random issues that slowly get worse and cracked insulation wherever it's visible such as at plug ends (as in your photo).
mattkh
England
A160 W168 1999 1.6
Very happy for you.
Q1. What did the mechanic do to the MAP sensor.?
Q2. If the engine has been running and you stop the engine, then immediately start again, does the engine fire up straight away or carnk long.??
B
Benzica
Zagreb, Croatia
1998 W163 ML320, 1994 W202 C180
  • #23
I can believe it. Some wiring looked redone when I bought the car. Also the horn didn't work at the time because of a dead wire.
Very happy for you.
Thank you. There is nothing on the bill about the MAP sensor and he didn't discuss it, but I imagine he had a look at least while doing diagnostics.
No change. It takes as long as usual. Furthermore, a couple of days after this work was finished, the crank's sound slowed down which I find a bit worrying. Perhaps it was too fast before and this is a good thing. I keep listening to YouTube videos of people starting up their C180s, but I can't come to a conclusion.
B
Benzica
Zagreb, Croatia
  • #25
It seems to me that the battery is dying.
Please check that the alternator is outputting 14v.
You were right. A few days after your post, my car was dead on the driveway. It's okay now after a new battery. The car occasionally cuts out when stopping or slowing down, but is still driving much better.
mattkh
England
A160 W168 1999 1.6
Very happy for you.
