w202 instriment cluster removal
Status
Not open for further replies.
hunter-haken
cheltenham
c250/1999/2.5td
Hi all could any body point me in the direction of how to remove the insriment cluster , as there's a couple of bulbs I need to replace
Iv searched but can't seem to find anything prob me just being retarded lol
Thanks in advance Andy
Best to remove a kick panel under the dash and push it out from the rear, not sure if it will clear the steering wheel on a non adjustable one
H
hunter-haken
cheltenham
c250/1999/2.5td
That's great thanks again for your help, there no rake adjustment so I guess that means air bag and stg wheel off
Try it,it may come out far enough, handy if you get the bulbs first from MB
If you have to remove the airbag, do not turn the ignition on or it will put the warning lamp on
spock500
Milton Keynes
300TD, 1998
The pod is held in the two fixings located at 10 & two O clock looking face on.
You can buy the removal tool but I made a couple from wire coat hangers.
Easy to do, two hooks at one end about the size of a penny then a hole at the other to put something through to help pull.
Slide both down at the same time then twist slightly to engage the fixing then pull - it's fiddly to get both at the same time, but will come out eventually.
H
hunter-haken
cheltenham
c250/1999/2.5td
Cheers for the info the coat hanger trick didn't work but it didn't take long to remove the lower panel and push the dash out from behind, there was enough clearance to get it out with out removing the stg wheel
Blooming typical tho put the dash back in and half the other bulbs blew prob from being old and bumped around
Been there and done it,,,, always change them all now days, I should have said ;)
spock500
Milton Keynes
300TD, 1998
Sorry, my post above should have read "as an alternative to Malcolm's suggestion"
I have the odd bulb go but nothing like a good clump doesn't fix ;)
horgantrevor
www.flickr.com
E220 CDI avantgarde c43//amg
The only problem with using the pullers is you run the risk of cracking the bezel
I have found pushing it from behind a better option nothing worse then trying to replace a broken dash clocks
So right, the glass on a 129 is near on £200 now, the 140 is the only real safe one where there are dedicated slots for the hooks
CafeMB
Banned
Grantham, Lincolnshire
Mercedes S320 CDI
I've removed the cluster on a W202 using the official pulling tools. The only danger with pushing the cluster from behind is that you can cut your hands to shreds due to sharp edges present in the area under the steering column.
WG M-B
North west london
C63 Wagon in black
You are right in that you have to be careful. 202's, however, are the worst model for cracking for no reason. I always advise getting a tin of silicone spray with a straw attached to the top. Gently squeeze a plastic panel removal tool between the dash and cluster both top and bottom, and spray some silicone on the rubbers. Leave for a minute then use the pulling hooks!!!
It works a treat :D
spock500
Milton Keynes
300TD, 1998
This is the guide I followed a while back.
The area where you need to get the hooks engaged is shown in red.
http://www.202tech.com/howto/instrument.html
You remind me of 202fan, you are always on 202 threads and never once on a S class thread, you use the same words too:confused:
Some guy on the internet
A few.
But television, you are on every thread, giving advice & telling people how to do things without the benefit of one minute of MB training or experience working on these cars in a dealer or independent.
You are so right,,I am a confidence trickster a cheat but please do stop exaggerating, I am only on ¼ of them. but I can blow the tyres up to the correct pressures :D:D
A few.
No that's not right, not a confidence trickster. More of an armchair expert based on an ability to copy & paste diagrams off an out of date version of MB's EPC.
Whatever you are, it is well know that to pull a W140 instrument binnacle out of it's resting place using the MB pulling tools will very often lead to expensive damage. Ask one of the indies on here!
HTH. :):)
Benzworx
South East
CLK 55 amg
it takes time and know how to remove any of the MB dash facias
take your time and treat it as if it was your own car !:D
Status
