W202 loss power cant go forward but reverse
pogilau
hi
Finally my jerky shift (only when it is cold) gearbox failed. It happened when I was stopped in a junction then tried to pull off but no power. It feels like the gear stuck in neutral, no power in D 2nd nor 3rd but I can do reverse. The engine and everything still running perfectly as usual, ATM oil changed 3 months ago and the car has full service. Before getting it to dignose by specialist or MB dealer to face a big bill, i wish here someone could give some advice. otherwise it will be sold as spare and repairs since i wont be able to afford to recondition the gearbox.
Your fault sound like a hole blocked or valve on the valve block. its only a sump off thing to check,,I can give addresses of good gearbox people near you
vijilants
London
W204 C320 CDI Sport
Get the codes read......sounds like a speed controller plate failure.
If it is the controller plate failure, you dont need a new gearbox, but the plate replaced which is under the sump.
P
pogilau
thanks malcolm that would be great if you know any specialist nearby.
by the way, I found a 1996 c200 mercedes gearbox, the parts dealer said it will fit on my 1994 c200, but i am not sure, will you know? thanks again
I have had valve bock faults, and this is listed on your as being that. where in the UK will you be
No 12 Mr Bruce Palmer
J P Automatic Transmissions
Unit 4a & 4b Pear Tree Ind Est
Upper Langford
N Somerset
BS40 5DJ
Tel: +44 (0)1934 852772
Fax: +44 (0)1934 852211
Web: www.jpat.co.uk
E-mail: info@jpat.co.uk
No 14 Mr Ian Chant
I.C. Automatics T/A Ron Cray Automatics
High Littleton Garage
High Street
High Littleton
Bath, Avon
BS39 6HW
Tel: 01761-472295
Fax: 01761-472295
Web: http://www.automaticgearboxesbath.co.uk/
These guy have a strict code of practice and do not cheat, not expensive either
