W202 throttle body change
theredguy
I am just about to buy a reconditioned TB as mine is leaking fuel and the idle valve/sensor bit is knackered according to my very "technical" local garage bod.
So is it just a case of a bit of common sense with taking all the pipes and wires off, removing the old unit putting the new one on and connecting it all back up and off i go again or is it a tad more involved?
Cheers.
japimport
The Emerald Isle
mercedes c200 sport,mercedes c200 elegance
how can you tell if your throttle body is knackered i have a w202 aswell whats the symptoms sorry its not an answer your looking for but im sure youll get plenty of info of other members im only learning myself
T
theredguy
Thanks for the replys guys, although mine is different to the unit in the link i'm sure it will give me some pointers.
As for my problems it is leaking a small amount of petrol from somewhere and it will not idle at all even when warm(getting used to left foot breaking now), and i also have to push the accelerator pedal to get it to fire up.
kth286
E320 Coupe 95
theredguy
You should get the codes read first and then go from there. There is no need to guess about these matters.
It may be for instance a diaphragm gone in the fuel pressure regulator; and consequently fuel getting through the ruptured diaphragm and flowing down the vacuum tube into the pipe into the throttle body, but leaking out where it ENTERS the throttle body.
Just one possibility, but get the codes read by an experience tech that is familiar with your generation car.
