W203 ABS Light
sidmon
Midlands
Mercedes 190E 1989 2.0
Got a late model W203 with an ABS light that illuminates after setting off. I've had my STAR on it and there's a code for the right hand side front ABS sensor but on checking live data there's no speed reading whatsoever from the front left side and the front right hand side is intermittent.
I've changed the ABS sensor on then left hand side hoping for a simple fix but no change. I've then checked the continuity of the wiring from the sensor to the ABS/ESP unit and all OK. I then changed the ABS ring and still no improvement.
I'm running out of ideas except to think there's a module issue, but it appears to be failing in a strange way (i.e. not reading the ABS/Speed sensors). Has anyone come across one failing this way before? There's no codes on star for anything except the front right hand side ABS sensor and a cruise control issue which I think is related to the first code.
bertb1
C220 amp sport 2013
Hello
I’m going through the same problem
I change the sensor then the ring and now the module on the abs pump I’m just waiting to have it coded to the car and hopefully this will be the end ( fingers crossed )
I was told that sometimes when the sensor goes it can send a surge back to the module
The 203 has a magnetic seal on the hub from memory.
If changing the seal do not press it all the way in as this will cause no or poor readings.
Knock it in till flush with the hub and check the gap. Flush with the hub should be about right.
Many people (myself included) knock it in too far first time.
Uncle Benz
West Sussex
Mainly Mercedes
Did you replace the right hand sensor that Star reported a fault code for? I’d do that first personally
sidmon
Midlands
No, only replaced the one that had no reading on the left. I might swap them around to see if I can get a fault pattern.
sidmon
Midlands
Does anyone know if the ABS sensors on a W203 passive or active? (i.e. do they have a power supply to them?).
sidmon
Midlands
Also has anyone tested their ABS sensors with a multi-meter? Just wondering what values I'm looking for?
sidmon
Midlands
Swapped the sensors right to left and still not speed rating from the left and still the code for the right side. I'm thinking the module has an issue. If I find an ABS/ESP pump with the same part number will it require coding with STAR? If so will this be possible with my 2014 version?
bertb1
C220 amp sport 2013
Hello
It will need coding I’m going through the same problem at the min
It’s dragged on for 3 months and still not sorted
sidmon
Midlands
Hello
Can I do that with my 2014 Star clone?
sidmon
Midlands
How replaced ABS/ESP module but still the same issue :(
bertb1
C220 amp sport 2013
Have had it coded?
bertb1
C220 amp sport 2013
Sorry have you had it coded
bertb1
C220 amp sport 2013
Hello
Can you please tell me if you had it coded as mine is going in on Monday but I’ve heard it’s a 50/50 chance of it working as some codes are locked in and can’t be changed
sidmon
Midlands
Sorry for slow response, been busy trying to sort it and I think I've hopefully cracked it. I've replaced the module with a second hand unit and have not coded it. I've then continued testing and I think I've narrowed it down to a module issue and seemingly a faulty ABS ring on the one hub which I which I'm waiting for a new one to be delivered to replace. I think the key is to replace any module with the exact same part number. Coding seems to be required for any modules with different part numbers.
Just hope I haven't spoken too soon!
bertb1
C220 amp sport 2013
I had the hub ring changed still didn’t work
I have had a module fitted with the same part number but it still needs coding
It is going in tomorrow to be coded but it’s 50/50 it will work as some codes are locked in apparently
I will let you know how I get on.
The only other option is to send the full abs pump and module for repair but this means draining the system
sidmon
Midlands
What year is yours? if you need it repairing I'd recommend AC Tronics, excellent friendly service at a very reasonable price. Same can't be said of BBA Remanufacturers of late sadly.
bertb1
C220 amp sport 2013
Mines w204 2013
I’m hoping tomorrow will be the end of it
sidmon
Midlands
  • #19
Best of luck, sure it'll be fine! ;)
www.ckinsurance.co.uk
