W203 c180 2002 elegance timing marks on camshaft please. The vehicle has tapperts noise.
Ians123
C180 2002 elegance
Am changing the cam followers.. The camshafts have no timing marks. Would like to know what position should the first cylinder cam lobes be facing
Is that the M111 engine (first three numbers of engine number)?
I
Ians123
C180 2002 elegance
Cams are locked and setup using pins.
Haynes manual might detail it all ?
Uncle Benz
West Sussex
Mainly Mercedes
Pin goes in the hole here, one for each cam.
Uncle Benz
West Sussex
Mainly Mercedes
From memory you put the crank at 20 degrees after tdc to get the pins in. The intake cam may take some joggling because of the cam timing adjuster. If you are a little unfamiliar with this engine you need to be aware of the proceedure for refitting the chain tensioner. It’s very easy to get it wrong and snap the intake cam. Hundreds of people have made this mistake
Uncle Benz
West Sussex
Mainly Mercedes
Thanks for the info.
You’re very welcome. Do look up the information on the chain tensioner. It must be stripped completely and refitted to the engine one piece at a time. If you remove it as a unit and refit it the same way the chain will be way overtight and the camshaft will snap within a very short time. I’m happy to give more info if you need it
I
Ians123
C180 2002 elegance
Thanks for that again. I will do that.
Regarding the timing holes on my intake side the is two holes on the cam gear. The small one being 4mm and not so deep. The other is the same as the exhaust cam. I assume I use the one which is the same hole as the exhaust cam.
Uncle Benz
West Sussex
Mainly Mercedes
Yes
