W203 C180k Oxygen Probe Fault
tesla
Registered
W203/2002/1.8
I have a fault on my 2002 C180K and would be grateful for any assistance the symptoms are:-
The MIL light came on; I got the error code P0130 indicating the upstream O2 sensor/circuit was at fault. I reset the fault but it returned a few days later, further checks revealed:-
Error messages [ignition on engine off]
02 volts bank 1 sensor 1 = N/A
02 volts bank 1 sensor 2 = 0.435V
And on another screen:-
02 volts bank 1 sensor 1 = [WR] 7.995V EQ Ratio 0.999
The top two readings indicate to me that sensor 1[upstream] is not being “seen” by the ECU & sensor 2 is “OK”.
[With engine running the upstream unit remains at N/A and the voltage from sensor 2 fluctuates within the expected voltage range.]
I am unsure what the second set of readings means as they appear to be well outside operating parameters.
So.......... After checking over the wiring between the probe and its plug, I bought and installed a replacement probe................and the readings are still the same
I would be obliged with any feedback relating to the faults above, and suggestions of ways ahead with tracking the fault – before I hand it over to the Dealership - thanks.
Uncle Benz
West Sussex
Mainly Mercedes
The only thing that springs to mind is oil travelling up the wiring loom from the camshaft adjuster magnet on the front of the cylinder head. I know it sounds far fetched, but the oil travels back and drops into the ecu, usually in the area of the lambda sensor circuitry, and creates this scenario. I hope I am wrong!!
The only thing that springs to mind is oil travelling up the wiring loom from the camshaft adjuster magnet on the front of the cylinder head. I know it sounds far fetched, by the oil travels back and drops into the ecu, usually in the area of the lambda sensor circuitry, and creates this scenario. I hope I am wrong!!
Does not the oil also go into the air intake and foul up the O2 sensors, the last one did a few days back
Uncle Benz
West Sussex
Mainly Mercedes
If this were the case, I would expect the new, replacement sensor to work for a while, at least...
Yes I agree, I will try and find the thread, I think that the oil ran down the cable into the MAF
I could be wrong does not the car have 2 O2 sensors
