W203 C220 cdi no crank no start.
LB9A
C220 CDi Coupe
No power on terminal 87. Code read can only access tcu and identifies problem with terminal 30 and gear selection indeterminate. Can't remember the code numbers.
Transmission fluid has wicked down the cable and left a puddle in the foot well
This wasn't' on star but the machine used has previously accessed all the ecu's.
Car had previously had non start and cutting out problems then 10 days ago it died totally. The AA recovered it to my home. Its now totally immobile.
Does anybody have any ideas or know of a mobil Mercedes-Benz specialist in the Hitchin area?
L
LB9A
C220 CDi Coupe
  • #2
The car now starts. The fault appears to be from the transmission. Hopefully a new conductor plate and connector will resolve the issues.
L
LB9A
C220 CDi Coupe
Thank you. I presume, from what I have read on the net, it is a common problem.
