w203 condenser replacement
peternash
Hello can anyone help me I need to find out how to replace a faulty a/c condenser on a 2003 w203 220 cdi. Thank you
LYNALL
Kent
Never done 203 but my 210 remove grill, cooling fans plus any other junk in the way undo pipes and remove, did mine on my driveway so cant be that hard!
Lynall
Hello and welcome,,there are many layouts of these rads, put up the next 3 numbers after 203
P
peternash
Hello if the number you ask me about is on the drivers door then it is WB2030062F218225
Thak you
I have sent you 3 Emails that cover this work
P
peternash
w203 condenser
Thank you for you help Malcom. I had a new condenser delivered and installed it using the info you sent me. I now have the a/c working in my car Thanks again for your help
noe173
New Registration
Malta
C Class C200
Condenser C Class C200 - W203
hi there
can any one tell me where the condenser of my C Class 2003 - c200 1800cc?
as just diagnosed that it is faulty?
any help how to remove it?
what the part no i have too look for when buying from net?
any good site from where to buy?
thanks a lot
Hello and welcome,,I can send you the info
johndlellis
Hi Malcolm
I've just spent a nightmarish weekend trying to remove the condenser from my W203 C320.
I can't get the pipes off the back of the rad; how on earth do they come off? And the electrical sensor next to the pipes; it must unscrew but it turns and stays where it is!
Also, it appears that you have to remove the galvanised chassis front crossmember to get the rad out, I now know why garages charge £500 to do this job!
Any suggestions would gratefully received.
Kind regards
John Ellis
I have not done this job so hard to advise maybe an indie can help out
deon.vhd
New Registration
KZN south Africa
Mercedes C220 CDI, Lancia Thema 16V turbo
Condensor replacement on W203 - procedure
Hi Malcolm
Can you please email the instructions to me. The a/c on my 2002 C220 cdi (W203)needs regassing every 2 months.
Hope it is the condensor if this is the most common problem for a/c leaks on these cars.
Regards Deon.
mikestrivens
Stockport
Hi Malcolm
Regards Deon.
I think Malcolm is away for a couple of weeks but someone else here may have the instructions or be able to help.
Tudor01
Registered
Iasi, Romania
W203 C200 CDI
Hey guys! I'm also facing the same problem, A/C constantly needs refilling. And I can't find a decent A/C specialist in my area, so I'm stuck trying to find out where the leak is, I hope it's the condenser.
Maybe Malcolm can help us out with thos instructions. My car is a 203.004
yaha456
w203
special thanks to malcolm
Thank u so much malcolm for sending me the sheets, i really appreciate your help:)
Andreas
220CDI - 2002 Model
I need to replace the condenser on my car. Does anyone know a website I can visit for instructions on how to do this, or can anyone please help with instructions. Many thanks
I can send you the instructions
giuseppe
Bournemouth
E220Cdi avantgaurde 2001
Changing the condenser you need to be F Gas qualified to handle refrigerants so one know's how to recover and dispose of the refrigerant, should one get caught you will be hung by the short and curly's and a hefty fine to boot,
I have sent the instructions Andreas
