w203 condenser replacement
Rappey69
hants
c220 w204 amg sport
I,ve just changed my condensor which i got from euro car parts..
I must say i cant remember the last time i spoke to someone on the phone that was so friendly and helpfull !!
He even checked the merc database to make sure i get the correct condensor, and a nice discount ;)
The job itself was horrible to do.. Hardest part was figuring out how everything is held together and where all them elusive nuts and bolts are hidden.
Rang kwik fit today to get system regassed.. they told me £49.95 :eek:
told them garage up the road is doing it for £29.95.
they then said they would do it for £25 !!! Bargain.
Now i have cold air for the first time in 4 years... Lets hope i have cured the leak .
cleverdicky
MB
Air con when the gas is low will often work OK on medium temp days say up to 20c, but in temps over that they do not work if the pressure is too low.
Just so you know, the various pressures will be the same in relation to any given temperature. Weather you have a system full of refrigerant or just a cup full.
Its the quantity by volume if insufficient while prevent it working well on a hot day.
mb220cdi2001
Registered
Bournemouth
mb 220cdi,2001, 2.2
please help with condenser
Could someone send me replacement instructions for ac radiator...mb 220cdi 2001...wdb 203006...
Aldomarco01
Dartford
C220 (203) 2004
W203 a/c condenser replacement
Hello television, Please could I also have instructions to replace my a/c condenser on my Merc W203? I noticed you were very helpful to a few other members
Steve@Avantgarde
Bristol/Somerset
Its easy, if you have a lift and the right tools.
Remove front bumper
Remove intercooler (if diesel)
Remove top slam panel
Remove cooling fan (again if fitted)
Push radiator forward (no need to drain cooling system)
Disconnect AC pipe and temp sensor
Unclip condensor from radiator and slide downward.
Reverse proceedure to install
Regas AC system.
Winchester
C220Cdi Sport Coupe 2007. Previously a 52 Reg Sport Coupe achieved 479,000
although mine hasn't been fully diagnosed, re charging apparently says there's a leak and the general consensus seems to be it will be the condenser.
Seadub
Registered
C180
Does anyone have instructions for W203 (C180 Kompressor) 2004 condenser replacement? They would be greatly received.
peternutkins
Charmouth Dorset
c220 cdi estate 2001
If its leaking there is probably no gas in it anyway, I have just put a can of DIY gas into mine and there is still no pressure, so that has no doubt escaped as well.
Peter
