Paul Goff
- May 17, 2017
- 2002 C220CDi CD Estate
I have done a search on this subject and have gleaned a lot of useful info but before I apply spanners thought it best to consult the all knowing ones on here ;-)
I have owned my 2002 C220 CDi for 6 months/4K miles now, and in recent weeks the fuel consumption has worsened by some 10%, particularly so when the ambient temperature is below about 6 degrees!
I drove about 120 miles in an ambient of 4C on Friday and took particular note of the coolant temp on the display, it never got as far as 80C. Back in the Summer it would get to just over 90.
While searching for info I found a very useful schematic for the cooling system on the car and a lot of great discussion.
Yesterday I went out for an investigative drive and expected to find that the MAIN thermostat had failed "open" but this does not appear to be the case. I stopped and felt the main radiator about a dozen times in total and even though I managed to get the display to read about 90 the rad was never more than about 35!
The auxiliary radiator/thermostat/pipes were a very different matter though, they fairly closely reflected the displayed temp every time I had a grope. At a displayed 50 the aux rad was warm but comfortable, at 65 hot but holdable and at 80+, OUCH At this point the main rad was still just tepid.
Apologies for the long windedness, here are the questions.
I understand that the main stat should operate at 92 C(?) I would say that yesterday it did not open at all because the coolant never got hot enough for it to do so? If it was stuck open, surely the rad temp, as measured by my sweaty paw would reflect the displayed temp?
I believe that the aux stat has failed open? What temp should it operate at? But is this circuit, along with the transmission cooling circuit actually capable of providing enough cooling to hold the engine temp down so far when it's cold out? I drive very gently nearly all of the time!
Thanks for reading this far ;-)
Lily Lightfoot.
Lily Lightfoot.
