W203 Electrics go off when i start engine
paulbooton
C270/2002/2.7cdi
Hi all
Any advice on this probelm would be great.
I went to start my W203 C270cdi this morning. It had been a freezing night and there was quite a heavy frost on the car.
Car started ok but most electrics wouldn't operate (heater, rear window heater, windows, heated seats, speedo, fuel guage, rev counter, indicators, maybe more). The radio and lights were working not full beam though.
I turned engine off and tried again. Same problem.
I then turned engine off and tried electrics without starting engine. All the electircs then worked perfectly. No problems. Heater, heated seats, indicators etc all worked without problem.
Started engine again. All electircs went off and i proceeded to drive to work freezing.
Cant work it out. I have tried taking battery off for a while and reconnecting but no luck.
Any help would be appreciated:confused:
Dec
Ireland.
W202
How old is the car and how old is the car battery?
Dec
P
paulbooton
C270/2002/2.7cdi
Car is 2003.
Battery is about 2 years old.
Dec
Ireland.
W202
It sounds like the battery is in poor condition, are you doing infrequent and/or short trips?
Convenience feature, the consumers you describe above, can become unavailable if there is insufficient voltage in the battery and become available again when the battery voltage recovers after starting, are you getting any warning signs on the dash display?
Dec
P
paulbooton
C270/2002/2.7cdi
Battery is in good condition.
I started again and this time it all worked. Went to garage to fill it up.
Stopped it and started again and heard a small clicking for a couple of seconds after the car started up. Again the problems were there.
Stopped it and started again. Didnt hear the clicking for a few seconds this time and all the electrics were working.
Seems like the clicking I hear after starting is causing the electrics symptoms.
Dec
Ireland.
W202
No idea I’m afraid other than to suggest you have someone start the car while you try to identify the location of the clicking when the bonnet is open, others may know more.
Dec
WG M-B
North west london
C63 Wagon in black
I would imagine the clicking to be one of the flap motors behind the dash. Do you have a spare key you can try? Failing this I imagine your car has a problem between the eis and the front Sam unit/ possibly rear Sam unit as well. Car needs to go on star to be checked properly
P
paulbooton
C270/2002/2.7cdi
Think I'll try locating the clicking with someone Dec. No doubt it will work fine every time when I try though!
Don't have a spare key WG. Looks like I'll need to get it on star then.
