W203 Steering shake when High Speed Breaking
CrazeUK
Manchester
C220 CDI 2001
Hey all.
I finally managed to sort out my ESP problem, man am i happy!!!
Now my next issue..
I get quite a lot of wobble on the steering wheel when i break at high speeds (any where from 40+).
It feels like its coming from the passenger side front wheel.
Any ideas?
It will be a warped disc if thumping through the pedal and the steering:D
mr mercedes knowledge
E63 amg
could clamp flexi hose and go for a drive to see if sorts problem out and eliminate each wheel
C
CrazeUK
Manchester
C220 CDI 2001
Yeah its quite bad, but it doesnt happen at all on low speeds.
How would i warp my discs?
They are cast iron, and the molecules in cast iron are always moving, one very hard stop can cause them to warp or go out of true.
I had this problem on my V70R after a very hard stop, it was not there all the time and could come and go, once again the heat from a hard stop would either right it or make it worse
Uncle Benz
West Sussex
Mainly Mercedes
Whilst this method does work, and we use it in the trade occasionally, I would not recommend that an owner takes to the road in their car with one flexy brake line clamped. The braking characteristics of the car will be greatly changed and a potentially dangerous situation could occur if you happened to require an emergency stop.
C
CrazeUK
Manchester
C220 CDI 2001
Lol, i understand the objective, but also saw the potential hazard or the car dragging to one side or the ESP playing funny tricks.
D:
cleverdicky
MB
Could just as easily be, (more likely than a warped disc) worn ball joint, track rod end or bushes.
WG M-B
North west london
C63 Wagon in black
The front control arm, front bush also causes this issue on a 203 when it perishes.
C
CrazeUK
Manchester
C220 CDI 2001
well i had the tires changed. tracking done. also apparently i had broken my passenger side suspension arm
Sent from my GT-I9100 using Tapatalk 2
