w203 towbar
john1
nr chesterfield derbys
c220cdi amg sport slk 200 r171
hi i am fitting a towbar to my w203 saloon and have bought a wiring kit from the dealer which has a bypass relay which needs a 12v permanant live is there any where in the fuse box in the boot that i can take a feed from
thanks john
Hello john, does not this plug directly into the rear SAM fuse box
What year is the car please and I can look it up this evening for you
Fuse 18 in the rear box is for the Tow Bar,,and fuse 17 is the trailer recognition circuits
john1
so i can just conect into the back of it
Not on the bus bar side,,on the other output side
john1
do you know where i can get wiring diagram of rear lights as i am having trouble identifying which wire does what
That is not easy,, what I do is to say turn on the side lamps, and push a pin into each wire till I find the live one.
john1
yes my usual method stick test lamp in each one in turn untill all identified but it wont work this time
By looking at the PCB should tell you what is what
john1
i have taken multi plug out of lamp unit and touched each contact in turn with test lamp but no result tested lamp on battery ok dont understand it
It can often be hard to get a good ground/ earth connection and I would extend the neg lead of the test lamp and fit a crocodile clip to go onto a ground point elswhere.
I will try and look up the colour of the wires,,but not my good point
turbopete
Spennymoor
2018 '18' Ford Edge tdci biturbo (sorry)
permanent live? do you have a caravan? usually only need that for caravans etc. single plugs are for lights only applications (trailerboards etc)
