Hi folks and thank you in advance for any help or advice offered.
So this morning i set about removing and cleaning the injectors. TBH the removal and cleaning went well and i did just one side the engine (3 injectors - pushed for time) and whilst i was at it changed the fuel and air filter. İ tested each injector by spraying carb cleaner through the nozzles before i replaced them and got a nice spray pattern on each one.
All back together and i fire up the engine but it wont immediately start...after a minute or so it starts but wont rev and starts knocking. İ get plumes of smoke so i switch it off. İ try once more but its the same and i decide the engine knocking is too bad to keep running or trying further.
Not sure what I've done wrong but i found a video from redat.com that says you have to preload the amplifer module inside the injector with iso oil and a compression tool....i didn't do this as i was unaware. İs my problem or are there others factors at work here.
Car is now at my lockup undrivable as i ran out of time strip it down again.
Any thoughts or suggestions?
