W204 c220 coupe 15 plate tyre issue
Rob Brown
W204 c220 coupe
Hi all, can anyone advise what tyre size should be on the rears of a c220 coupe? I've put some 19's on but the tyres seem to be really rubbing on the car. I bought them from someone who had a c250 so I didn't think there would be an issue but it's really not a good ride. I've put the current size up and what the alloys look like on the car.
Thanks in advance!!
JBell
Torquey
C350 CDi Estate (GAD Edition)
Wheels:
Front: 8Jx19 ET45
Rear: 9Jx19 ET54
Tyres:
Front: 225/35R19
Rear: 255/30R19
Your rear tyres are way too big
R
Rob Brown
W204 c220 coupe
Thanks mate, really appreciate it!! On the hunt now so....
R
Rob Brown
W204 c220 coupe
I've got 235/35 on the front, do you think they will be alright?
Bubble
Braintree
www.motacar.com
E350 Coupe CDI / Land-Rover Discovery 4 / Nissan Skyline 650bhp R.I.P.
The offset looks completely wrong to me, as they stick out much too far.
onefortheroad
uk.
At 70 mph with 235 35 19 . Youre doing 72 mph. The sidewall is also higher even though its 35 profile. So if you fit the correct tyres on the rear the cars profile will be wrong ..
KennyN
Paisley
Agree with the above , either that or you are running spacers that are too big.
What offset (ET) are the new wheels ?
K
R
Rob Brown
W204 c220 coupe
So basically, I've been quite stupid on this. I bought these wheels with not great tyres as I thought (and still do) the alloys would look good on the car. I saw the pic of the wheels on the vehicle which was a c250 so I didn't think for a minute I'd have an issue with tyre sizing. I've since replaced the fronts with 235/35/19 and as you can see the backs are awful (currently 265/35/19) so they need to come off ASAP.
So as it stands I will be replacing the backs with 255/30/19 but my question is do I need to replace my 45mile old Michelin PS4' 235/35/19 with 225/35/19?
There's a lesson to be learnt here but that's for another day....
Bubble
Braintree
www.motacar.com
I don't think that it is the the size that is the issue.
On my E350 Coupe I am running 275/35x18 on the rear, where standard is 255/35x18. This gives just 10mm extra wider each side, to help protect the wheel rim from kerbs. They look fine, don't rub and you wouldn't know that they were wider unless you checked the size.
The wheels that you have look similar to my Chinese copy winter wheels and they stick out further than the standard AMG wheels, but not to the extent of yours.
I think that you would be better off keeping your new tyres, selling the wheels and getting some new wheels with the correct offset.
R
Rob Brown
W204 c220 coupe
I didn't for 1 minute think there would be an issue because these are where the wheels came from.
Thanks Bubble I appreciate the advice. I believe the wheels offset is this;
Fronts:- 19x8J - ET35
Rears:- 19x9J - ET38
Is that wrong?
AMGeed
Poole, Dorset
S204 C180K
Is that wrong?
Yes, both offsets are wrong.
For a W204 C220 on 19" wheels you should have the following offsets
Front ET 45
Rear ET 54
This website might be handy to check offsets and part #'s should you want to get OEM MB wheels.
https://www.alloywheelsdirect.net/mercedes_alloy_wheels/c_class_saloon_w204_alloys
Bubble
Braintree
www.motacar.com
Is that wrong?
I honestly don't know the answer to that, but I do know that the lower the ET number, the more the wheels will "stick out"
Good luck with getting a good result!
R
Rob Brown
W204 c220 coupe
When you say wrong, is it that they won't fit on the car or just it's not ideal? Am i fighting a losing battle with these?
Gazwould
C250 CDI
And another lesson , some 255 tyres might be 265 !
JBell
Torquey
Front ET 45
Rear ET 54
10mm on the front will make no difference, there is loads of room in the arch, the rear is a different matter, the current tyre is way too big so putting a smaller one on will help the problem
R
Rob Brown
W204 c220 coupe
Thanks mate, the tyre I'm going with is a 255/30/19..... That should do it I think?
R
Rob Brown
W204 c220 coupe
Just wanted to say a massive thank you for all those that have helped me on this. Gone for these;
