W204 Clock Spring
Boydonegood
Rainham Essex
CL500 2002 & C350 CDI 2010
Hi guys
Sorry to bring this back up but am i right thinking the power for the Horn, Radio controls, Airbag, etc would be on the (after) the Clock Spring.. And the Wipers, Indicator stalk and the Steering Angle sensor are fed (Before) the Clock Spring?
Wipers, Indicators, steering angle sensor all work..... Air bag, Paddle change, Radio controls, Horn etc on the steering wheel do not. So im guessing it is the Clock Spring? £330 from Mercs.
Havent yet worked out how to test this fact!
If i remove the unit i can see there is the 8 pin connector for feed in (from loom that travels up the column).
Was gonna try checking continuity to the 2 clear connectors on the other side of the clock spring (that the steering wheel aligns with)?
Cheers guys, just dont want to spend the £330 if its not that!
Any control that is on the steering wheel goes through the clock spring. Anything on the column is wired direct.
There are multiple circuits on the clock spring so some may work and some may not dependent on the failure in the spring.
Boydonegood
Boydonegood
Rainham Essex
Cheers fella. Looks like I best give my £330 to Mercedes then. Oh well
Thanks for reply!
Boydonegood
Boydonegood
Rainham Essex
Hi all. Thanks so much for all the advice, today I replaced the Clock Spring and all is back working again.
Thanks so much
Tel
