w204 headlining
robbo21
lancashire
2010 c250 cdi bluemotion
can anyone help?
I have a 2010 c class. the headlining seems to have come adrift just above the rear window .I can feel what seems like a couple of clips on the underside of the lining and a couple of fixings stuck on the underside of the roof where I presume they clip into but I cant clip the lining back in place.am I doing something wrong or is it just fiddly to reattach it. would be greatful for any help .thanks.
All I can do is to look up the fitting instruction when I turn on.
R
robbo21
lancashire
any info would be greatly recieved .thanks.
I am looking now
I have printed off the headlining removal instruction and all clips are shown, thats the best I can do and I can Email it to you
R
robbo21
lancashire
thanks I have sent you a private message with my email address. graham.
All sent, I hope you can work something out :D
Mark Smart
C250 2012 AMG Sport
I have the same problem, could someone send my the link to repair?
This do?
  • 204 head lining.pdf
Mark Smart
C250 2012 AMG Sport
@LostKiwi perfect. Looks a big job to remove all the fixing and wiring. So start at the rear when re installing?
MinionBob
SouthWest
Viano - 2012 - OM651 Engine - 2.2
If this is anything like my Viano (and it looks the same) the headlining is attached to the car with velcro type strips.
Merc use double sided tape to attach the velcro to metal brackets on the headlining and this tape is the point of failure. The velco becomes un-stuck from the tape.
I cleaned up all the velcro, removed any double sided tape residue and stuck the velcro onto the metal headlining brackets using a product called 'Stixall'.
MinionBob
SouthWest
This is a pic of my Viano. The grey squares are where the velcro has become un-stuck (80%+ of the headlining). The black squares on the left of the phot are where I had previously instigated a repair, and these have stuck firm.
www.W140.co.uk&www.r129.co
