W209 Switched Live in ciggy lighter?
CLK Tim
Romey, Hampshire
W209 CLK500 2003, Altea FR
Could someone tell me (if possible) which wire is the switched live on a 2003 W209? I have pulled out the dash and I am trying to use the ciggy lighter wiring, but they are not standard colours (Ie, was looking for a yellow wire).
It's really annoying me :confused:
Thanks :D
If you have the cigar lighter out,, do you have a 3 pin socket where the lead to it plugs in
C
CLK Tim
Romey, Hampshire
I do and three striped wires, I was just going to harness the correct one for switched live but don't know which one it is.
I have one here and I will go into the workshop and check on what pin is what, and post back
With the socket facing you and the 1 pin at the top and 2 pins below , the right hand pin is the live. the left pin is ground and the top pin the lamp
C
CLK Tim
Romey, Hampshire
Thank you very much!! (Rushes off to complete car install) you are a star!
type49
:D
Standard colours?? What do you mean:confused:
What makes you think it should be yellow?
Got a feeling it could be black with a yellow tracer
They were yellow in the 129,s, and 124 I think
HelpThisDude
Essex
W203 C270CDI, R172 SLK55 AMG
All after market systems have red as perm live and yellow as the switched. Guess that is where he was coming from....
www.W140.co.uk&www.r129.co
