w210 320 cdi 2001
fireblade57
east sussex
e320 cdi 2001
got a problem with my e320 cdi engine wont turn over and stuck in park. Battery fully charged and also has a new brake pedal switch
Naraic
2005 CL500.
Explain a little more. When you place the key in the ignition and turn it...what happens?
It happens to me the odd time that nothing happens at all. I take the key out and try again...all works as it should.
F
fireblade57
east sussex
e320 cdi 2001
Was driving car and gears stopped changing up and down then abs. Light came on so i stopped switched off ignition tried switching back on and nothing and also now stuck in park
So the key turns and all dash lamps come on, then when you turn to start nothing happens.
Naraic
2005 CL500.
You can get it out of P by pushing a pen down the little flap at the end of the gear change just below "D".
It sounds like brake light switch is needed.
I do not think that the switch stops the car from starting and the switch has been replaced. The gear selector could be at fault, No gears before and now does not know when in park
Naraic
2005 CL500.
Oops...missed the bit about the switch.
Do these late cars have an indication in the cluster of the gear that is use, this is normally the clue
This will I think be a fault in the touch shift. Data code 116 stored in ECU this is the box ECU, only replace it when this code shows up.
We had a couple doing the same thing not that long ago
F
fireblade57
east sussex
e320 cdi 2001
Thanks for your helpful thoughts . I have changed the brake light switch and still did not start. Forgot to say the bas. Esp and abs lights came on as well as the car staying in one gear. Tried to start car again tonight but still no joy and still stuck in park even after pressing brake pedal hard. Took advice and put pen in slot and did free lever but car still immobile
Naraic
2005 CL500.
The codes will have to be read.
What is showing in the dash re the gear selection when you turn the key
www.W140.co.uk&www.r129.co
