Rory1980
- Oct 13, 2012
- Location
- Sauze Vaussais France
- 2001 e220 cdi
Hello
I ran a search on this but info seemed to be limited so il put it out there again. E220 cdi avantgarde 2001
Recently won an OEM double din Wood panel on Ebay as had been toying with the idea of fitting Command 2 - but now have decided to go an aftermarket double din.. These panels are rare rare and especially in my cars oem wood color so i thought i had struck a good thing.
However the clause is now that the double din donor vehicle also had the digital Klimatronic panel. A Klimatronic panel at reasonable price i have souced already..
But it has two Plugs.... where as my benz has one plug and the other some sort of pushrod setup to control the flaps
A bit more delving and i found a complete airbox from a vehicle with Digital Klima with all its stepper motors attached,
But its still going to missing a rather large part of the Loom /wiring harness to connect in this little Klimatronic digital pod and get most of it to work.
has anyone successfully done this?? im sure someone was fanatical enough to chase every factory option and retrofit this in a W210 !
Are we talking a piggy back wiring loom/harness of types that can come out of a donor vehicle and can plug into my cars existing loom to make all these stepper motors on the flaps work - or is my dream blown apart here and its just mission impossible without changing practically the wiring loom of the car which is basically not worth my while.
Advice please !
Advice please !
