W210 E class indicator issue
Onne
Ripley, Derbyshire
1990 W126 300SE
Hello all,
My colleague at work here has an issue with his LHD W210 220CDI
When indicating only the right hand side comes on, regardless of which way the stalk goes. (So when indicating left it blinks right)
Flash is at normal speed.
Any idea what needs to be done to rectify this?
Onne
Dec
Ireland.
W202
Is this OUTSIDE blinking or INSIDE blinking or both?
What happens when the Hazard Warning switch is turned on?
Try flicking the Hazard Warning switch ON/OFF repeatedly.
Dec
Onne
Onne
Ripley, Derbyshire
1990 W126 300SE
Both in and out, hazards work as normal.
Only way to get the left side to work is to press the lever down slightly, so not full contact.
Can it be shorting to the other side somehow?
No light faults on the dash etc.
Dec
Ireland.
W202
It all sounds very much like a component inside the stalk has failed, there are a lot of tiny springs and levers that control the indicator left/right operation, taking it apart to fix is not really doable so a replacement may be the only cure.
Can’t see any other reason for that fault other than a broken spring or a dislodged/loose lever causing the fault.
Dec
That proves it is the stalk that has failed, a common fault, it is a steering wheel off job and about £75
Onne
Onne
Ripley, Derbyshire
1990 W126 300SE
Thank you all, is it hard to get the wheel off?
I've not yet fathomed how to do it on my trusty old stead, let alone one of the modern jobs...
Remove air bag, the the center bolt
