W210 front suspension fail! Is this common?
ringo_notts
Basingstoke
W210 320CDI 2001
Just had the front wheel off to find out why the front suspension on the far side has dropped considerably.
I'm in shock.
It seems the mounting that holds the spring has come away from the body.
This is the other side which looks correct.
I can't for the life of me think how this could happen. I'm not even sure if I can by the parts to weld back on.
Thoughts much appreciated.
Ringo
mersum1es
Finland
That's common issue of W210 (Mine repaired as well). In Finland repair has been fully recovered by dealer/factory... Dealer repairs it by rivets, not welding. Spring cups can be bought separately.
R
ringo_notts
Basingstoke
W210 320CDI 2001
Thanks. Yes, a search for spring cup on google does show this as a common fault.
If one side has gone I should probably get the other side sorted at the same time.
Is this fixable with a mig welder?
Cheers,
Ringo
Roxie
Lincolnshire
C Class 350CDI 2012
Yes, buy new parts and if you are a capable welder and are sure you align the mounts correctly I see no problems. I don't know if I would renew both sides at the same time, however I would certainly have a good look at the other side to see if it needed repairing or replacing.
spock500
Milton Keynes
300TD, 1998
It's commonly known as 'spring perch failure' or similar.
As yet, not happened on mine but always mindful when approaching speed bumps ect.
If you are going to attempt a DIY fix let me know as I can dig out the official MB document on this.
You may also need a Klann type spring compressor to re-fit the spring. I have one somewhere in the garage ready for my turn :rolleyes:
Benzworx
South East
CLK 55 amg
This is not too common on w210's but can happen and is fixable with an MB cup and mig welder plus MB spring compressor
R
ringo_notts
Basingstoke
W210 320CDI 2001
This is great info thanks!
I would like to give this a go. There seems to be plenty of room for my spring compressors (which are pants but I have some) and its only one spring right!
The MB guide would be great. Do you need my email addy?
Cheers,
Ringo
spock500
Milton Keynes
300TD, 1998
I think it might be less common now due to most being fixed.
Take a look through this thread which contains a lot of info and may also have the MB pdf 'How to'.
http://www.peachparts.com/shopforum...e-read-crosslinked-post-1-all-topic-data.html
If the pdf is not there drop me a PM with your email addy and I'll have a look my end.
These springs are under a great deal of pressure. When I attempted to replace one of the springs (W202) with four conventional spring compressors I ended up cutting them off. The pressure bent them making it impossible to remove.
R
ringo_notts
Basingstoke
W210 320CDI 2001
I'm on my phone and I'm not paying this the attention it deserves, but I just googled klann compressors and they look serious.
Will check out the link above tomorrow on the pc.
Thanks guys.
Ringo
big_mike
My OSF spring perch let go on the 23rd of Dec as well, whilst sat on my drive! New bracings acquired (A210 626 01 19 for a '98 E300TD) was going to weld but riveting seems much more straightforward. Compressing the spring looks like it will be a nightmare but wonder how much it actually needs compressing?
chizzel89
Pembrokeshire
Mercedes-Benz C250 Turbodiesel Sport Auto. Estate. 1998. 180,000 mls
Rivet?! Sounds weak and rust prone! I wouldn't trust anything other than a high current seam weld, up so high that the weld burns in flat.
Frontstep
T210 320cdi
Rivets are strong enough, that junk steel rusts like mad after welding.
hmang
be careful of them springs mate theyre under a lot of pressure and if your compressors let go it could easily kill you.
sorry to be blunt
scotty2hotty81
Common problem, don't rivet, any competent welder can do this, peel the sealant away on the other side to inspect the condition.
www.ckinsurance.co.uk
