w210 Thermostat
merc911
Dublin, Ireland
Hi guys, can one tell me where the thermostat is located on E200 Komp, 2001 model. Temp gauge hovering around / below 80
M
merc911
Dublin, Ireland
  • #2
Apologies, the temp gauge actually rises to between 60 and 70 degrees, only goes to 80 when stopped in traffic
eric242340
Banned
China
If you give me the first six digits of the chassis no (VIN) I can locate it for you. But the question is why do you want to find the thermostat? Most thermostats are set to open at 75 degrees, therefore reaching 80 degrees for a short period is not unusual.:confused: :rolleyes:
Seems normal to me, 80c shows everything ok.
Malcolm
M
merc911
Dublin, Ireland
210048 - i just feel that im not getting suffiecient heat, particularly at foot level. Problem seems more pronounced on long journeys, temp gaige stays nearer teh 60 mark
eric242340
Banned
China
OK, this is a 111.957 engine and to find the thermostat - follow the pipe from the top of the radiator and where it connects is the thermostat housing. This housing is held by three bolts. This is a one piece unit, ie ; the housing/casing and the thermostat are one piece. When you remove it if the thermostat is stuck open then this is the problem. But if its closed (water tight) its not the problem. They are known to stick open on one side and this could cause your low temperature problem. However please note there are many other faults that could cause low temperatures.:rolleyes:
M
merc911
Dublin, Ireland
Thanks for that guys, will look into it today - you have given me the pointers that i needed.
Parrot of Doom
Manchester
On a similar note, is it possible to drain the coolant from the engine block of an OM606 by accessing the bolt from above, or do I need to get underneath?
M
merc911
Dublin, Ireland
Finally got around to changing thermostat, releatively easy diy job. Seems to have worked, temp gauge now reading 80. Not the cheapest thermostat that I have replaced (thinking back to the ford escort days etc.), worked out around €44- (£30) incl vat.
