W211 2.2cdi hazard light CP malfunction
Ivan Mihov
Royston
S203 C200 116bhp/W211 E220 147bhp
Hello everyone,
I bought an E220 which is been under water. I already proper drainage the car, I mean all seats and carpets been removed, washed and dried. I changed the front SAM to get car cranking then I changed a relay 1 on rear SAM and the car starts and works fine.
I have a two problems left.
1 Battery drainage which is from hazard lights control panel and
2 I am not able to scan it properly, no communication.
Thanks.
Ivan Mihov
Ivan Mihov
Royston
  • #2
I disconnected the headlights main switch just to eliminating it. The problem is coming on a night time and now I will waiting till 5pm to see what happens.Any other ideas for anything else?
Ivan Mihov
Ivan Mihov
Royston
Cheaper Delphi, I can scanning MB E320 65 plate whit it. Something is wrong but is a bit cold outside to check the pins on an ECU . :)
mattkh
England
A160 W168 1999 1.6
How high did the water come up ?
Did it come up to the top of the seats ?
Are the seats leather ?
What year is the car ?
Ivan Mihov
Ivan Mihov
Royston
My investigation working for the moment, I`ll still keep it you in touch till the end.
After headlight switch removed the hazard light control panel does not illuminate randomly and my 45AH battery still in good condition and I am able to start the car. That is meant new headlight switch.
Next step it is to find out why I am not able to scan the car and why the engine coolant fan is always on(it my be defective control module on a fan I think).
Thank you.
Ivan Mihov
Ivan Mihov
Royston
I have no idea how deep it was. I just get that car for scrap money. Previous owner did`t told me.
It is 04. The seats are not leather.
On the dash i got only engine management light for the moment. SRS disappear it self.
Strange???
Ivan Mihov
Ivan Mihov
Royston
Thanks .
When you removed the switch, was it wet ?
No...the switch was dry
When i took seats, cluster, all modules from the car I let it a heater inside for few days. Everything was fully dried.
Ivan Mihov
Ivan Mihov
Royston
mattkh Thank you.
Just to add some information for people who will need it in a future. I changed few thinks for the moment- Module 1(Front SAM) and Module 3(P/S/F foot well Under GCM- for some reason it is control module for passenger side headlight unit and other few thinks)
mattkh
England
A160 W168 1999 1.6
On the dash i got only engine management light for the moment. SRS disappear it self.Strange???
Thanks very much.
Have you removed the water from the headlamps ?
Also, is the air filter dry.
Ivan Mihov
Ivan Mihov
Royston
Wow ???? Silly me. I have been concentrate to solve a lot of other problems and i complete forgot to check the air filter. Thank you mate. You got a lager from me , i u are near me. ;)
And no water on headlights, fog lights and taillights . No water anywhere.
Silly engine light on and you know limp mode, no access to scanning the vehicle(just one option which is not enough).
BTW when I took it for a test drive does not show me on which gear I am. On my C class showed me.
I think I have to book it for a diagnostic on nearby independent workshop.
mattkh
England
A160 W168 1999 1.6
Before you take it to the workshop, try to dry with a fan heater, the inside of the car and any electrical connectors you can see in the engine lower down. Also blow dry the relay boxes, fuse boxes.
Ivan Mihov
Ivan Mihov
Royston
It is already done, it took me about a week or may be more , but now i clearly can see the difference between my car and others( for a moisture) my one is a bit drier ;)
The think is I no want to spend a money for a new ECU, Because I am not working for the moment and I tray to sort it out by my own.
Thanks.
Ivan Mihov
Ivan Mihov
Royston
Hello there ,
I found a problem whit no communication , defective(corroded) Central Gateway. I have a question about Central Gateway - it is need to be reprogrammed or it is plug and play?
Thanks.
mattkh
England
A160 W168 1999 1.6
Well done.
Just unplug and clean the pins, both ends. Then try.
Ivan Mihov
Ivan Mihov
Royston
Cheer mate. :) I order new one for less than 12 quit.
Do you know , do I have to reprogram new one(second hand) or it is a plug and play?
Let me showing old one:
mattkh
England
A160 W168 1999 1.6
Thank you very much for the photo,
Use a switch cleaner spray on the brown bits, DONT use a wire brush, just let it dry.
Use the same switch cleaner on the pins of the plugs
Use the same on the inside of the connectors
Allow to dry completely
Try this gateway first before you try the one you are buying
Ivan Mihov
Ivan Mihov
Royston
  • #19
New one just arrived today, it is a plug and play , next steps are to eliminate the rest of problems.... ;)
mattkh
England
A160 W168 1999 1.6
Thanks for letting us know. What is the most interesting problem remaining..?
