W211 E-class - Comand clock - change the time
grahamwoodward
Midlands
www.gwoodward.co.uk
W211 E320 (petrol) Avantgarde Saloon (2004); CL203 CLC180 Kompressor Sport (2008)
I've tried to change the time on the clock using my Comand system, but when I change the minutes (clock is 1 minute slow) it changes them by 30 mins only! (It's a 2004 W211 with sat nav/video/phone/multi-CD etc.). The handbook says you can't change single minutes when GPS is enabled. How do you temporarily disable GPS to make the change?
John Laidlaw
Wirral
Land Rover Discovery 4
There’s a similar thread with a million or so posts on the subject already ?
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
OK, thanks. I'll do a search.
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
I've checked the threads and the general consensus is "take it to your dealer". So, for the sake of 1 minute, I'll just look at my watch!
Wearsafoxhat
Sunny Hampshire by the sea
E55k :S211, SL500 :R129 , V220
I went to settings then time on the command head unit and input the correct time. Not sure if a minute out would bother me too much, I like to be early anyway.
Jimbo1959
Ayrshire
VW Scirocco. The Quattro, E350 CDi Blue Efficiency Sport Coupe, now both gone
I changed the time on my clock and the command unit changed itself to match, wonderful!!!
AMGeed
Poole, Dorset
S204 C180K
^ I did exactly the same as Post #5. Works a treat.
John Laidlaw
Wirral
My clock Comand and all changed itself!
