W211 E220 Rear brakes binding
spenttherent
E220 Eclass estate 2008
Hello
I've just replaced the rear discs and pads on my 2008 Eclass estate with genuine merc parts and they are now binding, both of them.
They have been cleaned and greased and the sliders, the pistons seem to go back easily enough, I can't think of anything else
Looking at a couple of threads on here and they point to new calipers
Does anyone know if we still get a dicount at Grangemouth Mercedes or is there anywhere else better
M80
Derbyshire
Wrong grease can cause the rubber to swell. The rubber can then gab the sliders. Are the calipers moving left / right ok?
Are the pads sliding within the calipers ok, I've had to grind pads down some in the past, but they're usually EBC.
Hello
How many miles have you done on them ? Might be worth doing 20 miles with some gradual breaking just to bed them in ?
ajlsl600
france
Doubt u need calipers, disassemble clean, one side at a time, check pads are free to move up to disc and back. Reassemble try again if not previously binding you have changed sommat.
spenttherent
spenttherent
The pads are quite free in the calipers and the psistons push back easy enough, but I did use copper grease on the pins maybe I should have used silicone instead , I'll have a look at that tomorrow, thanks
spenttherent
spenttherent
I was hoping that would help, Ive done about 40 miles so far and it has gone a bit better but one side is still getting over 100 deg
spenttherent
spenttherent
hope you're right, going to have a look again tomorrow if it's not raining, Ive done a few of these, never had this before
M80
Derbyshire
Copper grease will be the cause, w/o doubt.
Strip and clean with white spirit, you might be lucky but I doubt it.
Me thinks you need new rubber components where ever copper grease has contaminated.
Not for use on condoms though, being red it causes confusion.
EmilysDad
Bury Lancs
ML350
Is it a disc/drum set up at the back? Is it the pads on the disc that are binding or maybe the handbrake shoes in the drum?
Snake Charmer
S211 E320 CDI 2004
@Uncle Benz posted a useful tip about W/S211 rear caliper plastic pistons going out of round, might be worth considering.
Uncle Benz
West Sussex
Mainly Mercedes
Cheers for the heads-up!
The pistons are made of plastic. Mad, I know! With age they mushroom a bit at the outer end. When you push them back in they bind. I’m sorry, but a pair of calipers is the quickest fix.
spenttherent
spenttherent
It looks like I'll have to go with Uncle Benz on this
has anybody got any thoughts about this site ?
Or anywhere else with a good deal
spenttherent
spenttherent
but your choice
I know, but I'm running out of choices, I need to get them sorted once and for all
Ive been out this morning and checked the sliders and cleaned them but they were free anyway
  • Like
Reactions: M80
mersum1es
Finland
'mushroom' pistons are quite common and known feature of these... someone have been milling them back to straight, but if pad and sliders move freely, I would go next straight to new calipers...
www.W140.co.uk&www.r129.co
