W211 E320 CDI Glow Plug Light staying on after start up
Mar64
2004 Mercedes E320 CDI
Hi, I've got a W211 2004 Mercedes E320 CDI with some kind of glow plug issue.
When starting the car from cold the glow plug light comes on as usual before starting. However once it's started the glow plug light comes back on and stays on for around a minute before going out. BTW, the car always starts as normal with this issue.
I have checked the glow plugs with a multimeter and they are all ok. Next I removed and opened the glow plug relay box and found that one of the fuses had blown. So I replaced the relay box and it's also blown the exact same fuse inside the new relay box.
I assume therefore that it's a wiring issue, however I know very little about wiring. Could anyone give me a pointer as to where I should look next and what to look for?
Thanks,
Mark
00slk
Cambridgeshire UK
2002 SL55 AMG, 2005 E320 CDi,
Welcome.
You should really find an Indy and have the car put on the scanner, usually the best and most inexpensive way to get it sorted. You can keep buying parts and not find the cause and the scanners should get you in the right direction.
M
Mar64
Thanks for the advice, however I tried a Mercedes Indy before with a different issue on this car and they misdiagnosed and cost me a lot of money.
I'm interested in trying to resolve this issue myself first. As I say any help would be great.
00slk
Cambridgeshire UK
Yes sometimes they can get it wrong, I had had the same problem and cost me dearly. I too prefer to solve the problem myself, but electrics, that's a big no no for me and I have been told by my Son that I do not touch anything on a car that has wires!!! I can set fire to any car by just replacing a fuse :(
mattkh
England
A160 W168 1999 1.6
Thanks,
Mark
What are you calling the relay box.?
M
Mar64
You need to check glow plugs are O,K. If all good, then the relay.
I have checked the glow plugs with a multimeter and they are all ok. I then removed and opened the glow plug relay/control box and found that one of the fuses had blown. So I replaced the relay box and it's also blown the exact same fuse inside the new relay box.
Chloe87
A160
I just got my 2007 A 160 CDI two weeks ago, I am having a similar thing. It just started doing this on Wednesday after it went in to check the parking sensors. No fault codes were found at all, then when I collected the car, the coil symbol went out quickly, I started the car and it came back on, and now does this every start from cold and stays on for around a minute, maybe less before going out.
With the ignition on the symbol lights up and goes out straight away, but then on start up, turns over and starts absolutely fine it comes back on?!
I do have 3 month warranty from the seller, but I am new to diesels, Mercedes and glow plugs. Any help/advice would be greatly appreciated before I phone the seller and get to a garage.
One or more of the glow plugs have failed if the warning light comes back on after starting. Take it back and get the supplying dealer to rectify it
Frontstep
T210 320cdi
With a glowplug gone they usually start a little bit lumpy and you get some unburnt fuel coming out of the exhaust you could use your multimeter to check for volts at the plug end after replacing fused link to check wiring.
The glow plug control unit is on here somewhere with its top off, have a search.
andrew056
Devon
1993 SL320 gone but not forgotten , 2004 240 CLK cabrio, 2006 ML 320cdi gone, GLC AMG 43
If you're blowing fuses inside the relay that would seem to indicate that one of the glow plugs is shorting to earth . Or if the plugs are really OK then it must be the wiring from the relay to the plugs that's shorting out.
M
Mar64
I have checked the glow plugs with a multimeter and they are all ok. So as you say, I assume it's the wiring from the relay to the plugs that is the issue. I will look into this and report back. Thanks
Snake Charmer
S211 E320 CDI 2004
I've had a glow plug go dead short and blew the glow plug control unit.
Changed glow plug and control unit.
Sorted 2009 vito115
Still waiting for a report back from the OP.......
