W211 e320 gearbox problem
grahamwoodward
Midlands
www.gwoodward.co.uk
W211 E320 (petrol) Avantgarde Saloon (2004); CL203 CLC180 Kompressor Sport (2008)
Hi - the 5-speed auto box in my W211 E320 petrol e-class has an intermittent fault. When you start the car there is no gearbox info on the dashboard (ie. next to the mileage - no P, D, R etc and no S or W) and the trip-tronic selection doesn't work. The gearbox then stays in first gear. When you stop and switch off the engine, the gearbox will only go to Neutral, not Park. Start it up again and everything is OK. Last oil and filter change was 30,000 miles ago. Swith on side of gearbox was changed at last gearbox service. Car has done 145,000 miles. Any suggestions?
There should be a logged fault in the diagnostic memory buddy
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
Hi Wighty - last time it came up with a canbus error, and the reader could not communicate with the engine. It's going into my Indie's garage on Friday, who doesn't have Star but has a sophisticated reader. We'll see what that reveals. Thanks anyway. Might start looking for that CLS500 I've had my mind on!
mersum1es
Finland
Check TCU and harness oil contamination
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
Mersum - what does TCU stand for and where is it?
star
Reading
Smart + others :)
I would say gear selector.
bembo449
gainsborough , lincolnshire
Transmission control unit , a decent dcan tool should diagnose the issue but head the suggestion above pal
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
Star - what do you mean by the gear shifter - the stick inside the car? Sorry to sound so ignorant but I'm not a mechanic.
Uncle Benz
West Sussex
Mainly Mercedes
Most commonly the gear selector module gives the symptoms you describe. It's the unit with the gear lever attached to it.
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
Thanks guys. I'll pass that info to my man and let you know the outcome. Keep Safe.
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
Update - gear selector unit removed and taken to a local repair centre (ECU Testing Ltd, Heanor, Derbyshire) - it was faulty, repaired same day, cost £230. Cheap at twice the price. Just got to refit it now. regards.
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
RESULT - refitted the gear selector unit today and problem solved. Thanks Uncle Benz and others - you made solving the problem soooo much easier. Keep safe everyone.
