W211 estate tailgate strut replacement
PaulThomasFarrell
London UK
E220 AMG Night Edition Prem Btec A
MB. E320 CDI 2004 W211 Tailgate gas struts replacement
I bought a pair of struts for the above mentioned model from a breaker in Lithuania on E-Bay, they were advertised at £50 but I offered £30 and got them for £40. They arrived within the week and I tagged the 24th December to have a go at installing them. Now bear in mind I had no idea if these worked so it could have been a disaster but with the help of Mr Televisions instructions off I went.
The reason I felt I needed replacement gas struts was that my tailgate had suddenly started to try to kill me by unexpectedly dropping onto my bald barnet as I was loading my tools, god that tailgate is heavy unsupported.
Each end of each gas strut is a ball joint that is pressed onto a rigid socket at each end. One is fixed to the car body the other to the tailgate.
DANGER: Make sure you prop the tailgate up securely before you start work. Being an undertaker I used an old coffin lid and it was perfect.
Also buy some masking/gaffer tape and generously tape about 6" around the exposed hole that is seen once you've dropped the coat hanger hook (both sides) using a torx screwdriver bit. You really don't want to get oil or gunk onto the roof material and there will be lots in there. I also bought a box of disposable gloves and changed every time any oil or dirt got on them.
Shine a torch through the exposed hole/s and you will see a diamond shaped plastic cap. Prise this off with a flat screw driver then swear like mad as you try to get it out of the hole...it does come, eventually, I found looking just made it worse, close your eyes and use the force... You will then see the ball and socket joint of one end of the gas strut. I inserted a blunt wood chisel into the hole and with a lot of cursing levered off the strut from the socket. It actually wasn't that bad.
Then at the other end I was stumped as to how I'd get the strut out...it definitely wasn't coming out the coat hanger hole end. Then I remembered reading on here the post that mentioned the black plastic poppers with the little pin in the middle that hold trim in place. There are two of these holding the trim in place top right and left of the place where the tailgate hinges are.
Use a small flat bladed screw drive to tap the middle of these poppers and push the pins out. (try to find the plastic middle bit so that you can re use them) Then with long nosed pliers, firmly grip the now pinless popper and they'll slide out. The plastic trim can then be moved about allowing you access, albeit tight, to the other end of the strut.
Same procedure with the flat chisel and the other end was levered off the socket. I was then able to pull the old strut out through the rear.
Installation is the reverse. I popped the coat hanger hole end first and it was easy to lever back on. I can't tell you how I managed to get the rear end one back on but it took an hour of patience and tenacity, and it eventually clipped on. I had to lower my coffin lid support a little to align the strut socket to the strut ball.
I removed my coffin lid support and it ****** well worked! Hurrah!
Garage wanted: 2 hours @£110 per hour plus VAT plus two struts @ £120 plus vat for the pair.
£408…….
Total job cost me £40. (my time is free to me but it took three hours.)
Doing the work requires time and patience and of course the right tools at times.
Happy to discuss if my explanation sucks.
Love this car.
And thank you to Mr Television.
Pretty much the same way I did my 210 except I couldn't find a coffin lid so used a broom.:)
Well done persevering.
EmilysDad
Bury Lancs
ML350
makes changing Roadster Coupe's corroded ally tailgate hinges a doddle by comparison .... ;)
  • 211 tailgate strut.pdf
Gary31
That's terrible news, he was great chap and a wealth of knowledge.....
Mercedes_Traveller
Registered
Mercedes-Benz E220 2004 Estate
Hi, I don't have power operated tailgate. Is the file given by LostKiwi same for me? My tailgate doesn't stay open and presumably I need new springs.
Also would anyone know if power operated tailgate can be retro fitted?
Thanks!
PAGarside
Registered
2004 E500 Estate
You are most kind.....
Hi Pete,
I was wondering if you still had these files, and if so, could you please email them across to me.
Many Thanks
Pete G
Hi Pete,
Many Thanks
Pete G
There are links and attachments all through this thread for doing this
CAPTAIN BEAKER
E320 CDI ESTATE
£408…….
Love this car.
CAPTAIN BEAKER
E320 CDI ESTATE
Was that on a powerlift tailgate model as I've read its necessary to remove the headlining.
Much easier if it can be done without?
WibbleWobble
New Registration
E220 Estate 2005 2.1
Hi all, new to the forum and I have the same issue with the tailgate on our 2009 w211 estate.
Malcolm, would you be kind enough to email me the instruction on changing the gas struts?
Many thanks.
Also does anyone know if these are direct replacements? They seem cheaper than expected and don't look that similar to what little I can see of the current ones.
http://www.sgs-engineering.com/car-...class/gsc1672-mercedes-e-class-tailgate-strut
Many thanks, Rob
Don't go near SGS with a long s****y stick. In 2020 they are still advertising the wrong struts. I got burned by them. They do not sell the correct struts, but still keep advertising them. They are wasting everyone's time, including their own. You think they would learn!
EmilysDad
Bury Lancs
ML350
Had no problem with SGS a few years back getting replacement tailgate struts for EmilysGrandad's MKII Granada estate. By rights the strut they sell didn't have the correct sized thread on the end ... they told you that when you ordered them but offer a service to adapt the new struts with the end of the old struts ... but I made an adaptor to make them fit. They worked well.
