W211 facelift 2008 e220 juddering under acceleration with black smoke
Remon Yousef
E class/2008/ 220
Hi, my e class 2008 done 180k miles recently when I accelerate around 3k rpm to over take it start to judder feels like I am pressing the gas peddle on and off and it leaves a cloud of black smoke behind.
At normal speed it drives fine no problem only under harsh acceleration can someone put me on the right direction where to start.
Ps I had the car diagnose by delphie no error codes and no lights on the dash or limp mood.
mattkh
England
A160 W168 1999 1.6
Is car diesel?
Is car an automatic?
R
Remon Yousef
E class/2008/ 220
E220 diesel auto
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
I'd have the injectors tested if no fault codes showing.
mattkh
England
A160 W168 1999 1.6
Any service history on the car?
At that mileage, there is bound to be a lot of carbon buildup in the engine.
R
Remon Yousef
E class/2008/ 220
Unfortunately when I bought it there was no service history with it, one month ago I done full service, the injectors seals was leaking so I cut the seats and put new seals now no leaks from the injectors, also changed the thermostat so the engine reach 90 no problem.
Today I am planning to take the egr off to check it and give it a good clean!
I wish I can take the manifold off to clean it and check the flaps but it looks very complicated.
Larkone
NW Essex
C219 CLS 320CDI 2008
Had that happen on my OM642 - it was the turbo actuator, just needed cleaning and greasing
R
Remon Yousef
E class/2008/ 220
Was your actuator manual or electronic one, when I looked i looked it up it looks like mine is electronic one.
mersum1es
Finland
It is electronic on OM642 too. I wouls suspect that too. Does it rev over 3000rpm? If so, it is not in limp and codes may not trigger.
R
Remon Yousef
E class/2008/ 220
Little update, I spend a good 2 hours trying to remove the EGR but unfortunately it won't move, I just managed to move it right and left just slightly but that is it.
Any idea?
When the tanks empty fill with a premium fuel (BP ultimate) and shoot some redex type injector cleaner.
fuel filter recently replaced?
R
Remon Yousef
E class/2008/ 220
Yes fuel filter replaced a week a go Man filter
CowleyStJames
Oxford
Should've flow tested the injectors whilst they were out
