w211 intercooler hose
pomm001
leicester
SL 500 R231 A clas W169
On my way out this evening there was a loud 'whoos' noise and loss of power. A little further i popped the bonnet and fond that the intercooler hose just near to the air filter had become diconneted.I pushed it back in as best i could and limped home.
My question is:
is this common? and does it signal any other woes, ie should the intercoller come off and be washed out ? does it need to have new retainer clips ? the vehicle has 90 k miles and has always been faultless
any suggestions welcome
many thanks
pomm001
pomm001
leicester
  • #2
Forgot to add its a 2.2 diesel
Cole@MBS
www.mbssouthampton.co.uk
Common as muck, i will have the hose sitting in the shed. i keep all the boost hoses as they all split over time!
pomm001
pomm001
leicester
Thanks for they reply
as its come off at the joint what would you suggest, if i just re attach it its bound to come off again, replace the hose , the wire clip or the lot
pomm001
pomm001
leicester
My question is:
many thanks
After some more investigation it seems that the plastic housing at the turbo is damaged where the retaing clip locates , see very porr pics, also the aluminium pips on the collar of the hose are quite worn where they have been acting like a piston when the boost comes on.
Suggestion needed, the pressure pipe is OK it not split or leaking, should i replace this at the same time, would MB be the best place to get the plastic housing from
many thanks
Cole@MBS
Thats the other common thing with them, cheap plastic housing!
Only from mb i think!
pomm001
pomm001
leicester
best get saving
pomm001
pomm001
leicester
Plastic adaptor to hose from turbo £36.00
pomm001
pomm001
leicester
I replaced the plastic elbow, checked the rubber hose,it looked in good order, the little raised 'pips' around the aluminium collar showed some wear, made sure everything was A OK and put it all back together without replacing the hose.
Now a couple of months latter the ****** thing has 'poped' out of the intercooler end this time .
I spent a lot off time making sure that everything was OK and the clip was seated correctly when i put it back together, i even took the intercooler off to give it a clean out and check the connections .
Logic says replace the hose now
Have you come across this ?
the car has done 90 ood K
The stragest thing is on both ocassions its failed it has been on the way to my favorite pub, i wonder if that has anything to do with it ?
pomm001
pomm001
leicester
after taking it off, it looks as if the retaining feature has now worn through and opend up like a sardine can , see picture.
Disconneted the lever to the turbo wastegate and that seems free enough so presume it not stuck shut anything else is should check
many thanks
Cole@MBS
New hose will cure that, i have filed the edges before to make them grip but that one of yours is shot looking at that photo!!!
New hose, happy days!!
