W211 parking sensors/wipers
The Joker
2004 W211 E320 CDi
Hi all,
The front parking sensor lights on my 2004 E320 Cdi have started to come on when I apply the brakes. It only happens occasionally, with normally the inner 2 lights coming on for 3-4 seconds & then going out. Can't tell at the moment whether the rears are doing it as well.
Also......the rain sensing wipers are playing up. They seem to work OK until you accelerate briskly, then they start working all the time, as fast as the normal wiper speed and don't return to intermittent. If you switch them off & back on again, they are OK until you accelerate again.
Could these things be related?
Your thoughts would be most appreciated.................Joker.
xavierx
2004 W211 E320 CDi
If the 2 red lights are coming on when braking (and a bleep noise) then you have a parking sensor fault
If it is 2 yellow lights when almost coming to a stop then it is normal
Kind regards
They are odd faults,,see if I can find a clue later
T
The Joker
2004 W211 E320 CDi
Hi and thanks for the replies,
It's the two yellow central lights that come on when nearly stopped, with no bleep.
Thanks for that Malcolm........................Joker.
xavierx
2004 W211 E320 CDi
2 inner yellow is strange, it should be 2 outer yellow when coming to a stop
T
The Joker
2004 W211 E320 CDi
Mm..... will have another look and let you know as soon as the better half lets me back in it!
Any ideas on the wipers?
Cheers...........Joker.
xavierx
2004 W211 E320 CDi
When you say they speed up when you accelerate, do you mean when it is actually raining?
Merc wipers seem to be super sensitive, much more so then any previous car I have had. Of course if you are accelerating into rain then there is going to be more rain hitting the sensor area of the windscreen.
Make sure that the rain sensor part of the windscreen is super clean. Try some "glass cutter" or similar polish from Halfords, it removes ingrained dirt and minor scratches and helped solve a simular problem on a Peugeot 406 I had in the past
You have two difficult on the car,,the wipers should be something in the OCP that is the ECU within the mirror housing.
If you know an indie with STAR this will identify both faults, then we can take it from there
