W211 Parktronic sensor problem
Maku
E 240 full AMG kit
Hi
I am having the same problem as well. Could someone send me the instructions too? Many thanks.
I have a E-class 2003 with AMG body kit.
tonglongpai@hotmail.com
Cheers,
I have sent them and you can edit out your address
Please ask a mod if it can go to,the diy section
Turbo Merc
Hampshire
E320 CDi
That's a good idea as this is a very common problem that is easily solved by most people. How do you contact a moderator? I have searched but cannot find anything.
Send a PM to Miffy, Niarac or whetenemises
noobievan
Bristol, UK
2004, E320 CDI, Elegance
Televisions info sheen on rear bumper removal
I was hoping to get the info sheet on rear bumper removal from Television.
E320 W211
All sorted now
yeh yeh
Can I just stress that two or more sensor can and has gone at the same time, as it happened to me, I went about buying one to replace one at the time,after I replace all 10 a couple of hour later with no joy, in the end took it to my garage, run it on his laptop,and he pinpointed that two sensor has gone,the two corner ones at the rear,as everyone knows, corner means where the wheels are, ask for the old one back,sure enough, I open it up,and it's very wet in the electronic,and not on the connector.the sensor cost £53+vat
747skipper
Poole Dorset
CLK280 Elegance/2008/2996 now 2018 C 250d Cabriolet
Hi Malcolm
I've studied Turbo Merc's very clear guide to strip removal on his W211, but unfortunately it doesn't seem to apply to my CLK280, W209. Am I correct in thinking it's a bumper off?
If so please will you send me details of how to do that?
Front CLK 280 2008 W209 Convertible.
Many thanks in advance.
David
merc@747skipper.co.uk
Longshanks
Belfast
2008 280 CDI Sport Estate
Similar Parkronic problem from a newbie.
I too am a new owner, 1 week in, and when I engage neutral or reverse, I get a beep and all the rear sensor lights come on and stay on until I shift into drive, the rear sensors do not function, although the front ones seem to be ok. Any advice would be appreciated. Thankyou.
You have a faulty rear sensor Sir :D
Longshanks
Belfast
Faulty rear sensor.
Thankyou for that Malcolm, does that mean I need to have the fault codes read to determine which one?, I take it my Mickey Mouse code reader won't do the job?. Thanks again, David.
whitenemesis
CLS55 AMG '05
STAR is the only one able to read the chassis codes. It will identify the faulty sensor(s), saves a lot of guessing.
Longshanks
Belfast
Just read somewhere that a functioning sensor " clicks ". I happen to have a stethescope somewhere, brings a whole new slant to diagnostics!. Will let you know how I get on.
David.
This will not work if the ECU has shut down, you can try it.
rookie2012
Sweden
E320 W211
Hi Malcolm, could you please send me the docs on how to change parking sensors on my car?
cdk_dosk@hotmail.com
It is a W211 E320 Estate (avantgarde) 2003 year model.
The sensors seem to sit into some kind of strip on the bumper.
Btw, do I need special tools?
Thanks alot :)
