My trusty E320 has done 147.000 miles and goes well. i understand the timing chain should be changed at this stage . there is no sign of any noise from that area . what are the risks ?
same as with any belt or chain , it can go without warning so if its not been done before and you feel its best to renew it , then I say crack on ! you will only regret it if the worst does happen pal
Again .............. these are duplex chains unlike your M271 simplex chain and sprockets that failed as its a common fault on your engine and other manufacturers that use a simplex chain EG: Vauxhall Corsa VW Polo Peugeot 207 BMW N47 M57 engines especially bad.
GAD was founded in 2009 where we developed bespoke ECU Remapping software for motorsport clients, moving forward, we have extended to road vehicles for both performance and economy, contact GAD Tuninghttp://www.GADTuning.co.ukto discuss your requirements.
