Aston Dabb
- Jan 5, 2020
- W212 AMG 2010 E350 CDI
Hello all,
Got an E350 CDI that seems to be idling at 800rpm instead of 600rpm ONLY WHEN CLIMATE CONTROL IS ON! When I plugged it into the Xentry I got Component ‘B37’ (Accelerator Pedal Sensor) is defective. At the time, the EML & ESP warning lights had just come up. Both with faults relating to this Component B37 Pedal Sensor. But I do not know why this would make it idle higher than it should do. I’m aware that this is common on the E350’s. The vehicle doesn’t get used very often at all if helps. It also has a jerk/flutter/misfire when driving and at approx 1500rpm but I think that is the fault with the defective accelerator. Any help appreciated thanks!
